>Two seemingly simple questions: I am planning on putting 5/8" OSB paneling in my garage. What length screw should I use, and does anyone see any problems with using OSB in a garage. Of all the options that I've looked at, it seems to be the most cost-effective.
John, who knows how he'll be spending his snow day tomorrow
I think 1 5/8" coarse thread drywall screws would work fine. That would give you an inch of threads int he wood and I think the screws would hold so well at that point that they would either break or pull through the OSB, so that's all they can do.
The only objection I can think of to OSB is that it is not fire rated. Or should I say, it burns readily. Actually, you can use it for kindling if you are having trouble lighting gasoline.
Local codes require fire rated drywall between the house and garage. That's a simplistic answer without all the details, but if the garage is attached to the house you might want to put up drywall first. Or check with your local Code Enforcement Agency. (Under an assumed name in case you don't like the answer.)
Beyond that, it makes a good utility wall. Paint it white and then you can hang stuff anywhere that suits you.
>Thanks, Barry. The common wall between the garage and the house already has dry wall on it and I won't bother putting paneling on it. The outer walls will get OSB and a coat of paint come spring.
>I sheathed my garage with OSB...other than the smell, which I find somewhat objectionable...no problems...OSB and plywood have about the same fire rating...see link below
