Cold weather air compressor operation - - results
Pete in Holland, MI
>Guys -
Posted a message a few weeks ago about using an oil sump air compressor in cold weather.
As some background, my compressor would struggle to get up to speed if the temperature was below 25 degrees F without blowing the adequately sized breaker (yes, all the wiring is adequate). Was thinking about switching to a synthetic oil over the OEM petroleum based oil that came with the compressor and received some feedback from you.
Headed to Lowes, then Home Depot, then ended up at Tractor Supply before I found some "all weather" synthetic oil. Cost was less than $5 for my compressor.
Warmed up the compressor head, drained the OEM oil (which was getting kinda dirty) and replaced it with the synthetic.
I am happy to say that yesterday, when it was 4F degrees in my garage, the compressor started up like it was 60F degrees outside. I highly recommend this upgrade to all you folks with compressors that live in cold garages.
Pete
