OT - Solar Water Heater
Tony - Memphis
>I don't like OT questions, so I feel a little hypocritical asking one, but here goes. Our water heater is nearing its EOL. It has been in use for 9+ years. I'd like to go solar. Has anyone done this? Any good sources, tips, etc.? I haven't found an installer in my area, but I have seen several DIY "kits" online. We don't use much hot water (just me and SWMBO), but I figure its the most affordable way to head green.
Thanks,
Tony
Re: OT - Solar Water Heater
>When all the costs and hassle - purchase, installation, setup, operation, and maintenance - are considered, I think the least expensive approach is a super-insulated electric unit on a programmable timer. For just two people with regular habits, it's hard to beat.
Clint
Hank Knight
>Tony,
My doughter's boyfriend just last week finished installing a solar water heating system at his farm house in Kentucky. I'll be glad to put you in touch with him if you don't get the info you're looking for here.
Hank
>I tend to agree with Clint. I had a solar preheater for about four years. It was pretty crude and home made. A 4' by 16' collector made of the pipe out of baseboard heat. A piece of foil faced foam insulation painted black behind the pipes and a forty gallon tank above the unit. It thermosyphon. When the sun was shining, it would just cause the hot water to rise into the tank and colder water to circulate back to the bottom. Nothing in the way of freeze protections. I ran it then moths out of the year and just drained it the other two to prevent it freezing. At the end of a nice sunny day I would have forty gallons of water between a hundred and hundred twenty degrees. That fed into my electric water heater, which would top it off if it were not hot enough. I actually installed a meter on it and it saved me forty percent of the energy I needed to heat hot water. After a few years the tank failed and I shut the system down. I probably should have kept it going, but it turns out my neighbors trees have grown so large that they now shade the collector area. And there are too many drab cloudy days when the collector is not effective.
I think insulating the tank and the pipes and then using a timer will be very effective, inexpensive and much less of a PITA.
Glenn Madsen, near San Francisco
>We're on the other side of the country, and so what works here may well be much different that what works there.
But I'd be very surprised if you couldn't get something from the local electric and/or gas utility company. At least here, there are incentives which are offered to consumers to reduce the total electric load on the grid, and the technology to do so, which the companies have approved, are identified. You will still have to choose from a list of folks to do it for you, assuming you don't want to run the plumbing yourself. It is a very attractive do it yourself project, though you'll want to do it right. It's your culinary water you're working with, directly, unless you use a liquid to water heat exchange system.
Where we are, several of the neighbors have their swimming pools heated this way. I don't know if they use them for domestic hot water.
Dale Warder
>Tony, when we lived in Memphis, many years ago, there was a program sponsored by TVA to install solar water heaters and subsidize the installation. I beleive they actually provided a collector and tanks as well as financed the instalation. I don't know if this is still in effect but you might contact them for information.
Dale
Re: OT - Solar Water Heater *LINK*
Jason in Reno
>The Home Power website has a lot of archived articles about various solar hot water systems. Some of them are free and some not. Scroll down a little and you will find a link to articles on this topic.
Home Power
