Maybe a stupid question (Thus is probably is!)
Terry Alexander
>I have a 30x40 workshop (metal building).
I am replacing a washer and dryer and am wondering if I wire a 220v receptacle for the dryer, can I vent the dryer to blow the warm exhaust into the shop in the winter?
As always...TIA
Terry Alexander
Re: Maybe a stupid question (Thus is probably is!)
Dennis Jackson
>I think you could, but there are some things to consider: the humidity(including the added rust to the machines and the moisture content of wood), the inconsistant source of heat (unless your big family keeps the dryer running constantly, and the lint that the dryer doesn't catch which will add to finishing problems.
Not stupid
tek-Brunswick, Ohio
>Yes, you can vent the dryer inside. There are two things to keep in mind. All the water the dryer removes from the clothes will be vented into your shop. You need to trap the lint that comes through the system. I saw a product once that filtered the air for venting inside. An old nylon stocking over the end of the pipe might work.
Steve in Denver
>You might want to add this to your set up.
http://www.improvementscatalog.com/home/improvements/75991-indoor-dryer-vent.html
Do it all winter
Bill Howatt
>I vent our dryer into the basement every winter, and yes, it vents right into the shop. The pipe runs down to about 2' from the floor and I put an old nylon stocking on the end. It traps the lint very well but if you were finishing a critical piece it probably wouldn't be adequate.
I wired up a switch so my wife can turn on a shop fan when she runs the dryer. This blows the moist air around so it doesn't concentrate in the shop. You will notice a lot of moisture when the dryer is first started then it gradually dries out to nothing (my basement block wall gets very wet by the pipe).
I can't say venting causes any problems but you can put paste wax or other products on your exposed cast surfaces to further minimize the effects of moisture.
Benefits are it warms the basement and also humidifies the house which is needed here in the winter.
Bill
My results were not good
Neal in San Jose
>One day after a couple of weeks of not using the shop, I went out to do some WWing. I noticed the top of my table saw and jointer were covered with a light brown patina of rust. I checked further and noticed that EVERY cast iron surface in the shop was similarly affected. I live in a near-desert environment, and rust has never been a issue before, so I checked out the dryer vent and found that the plastic hose had broken, doing exactly what you are proposing. I wouldn't do it, but it sounds like others are getting away with it. YMMV
Same here
Rick Christopherson
>I have my dryer vented into my garage because getting to an outside wall was too difficult. This isn't my workshop, but I do have a lot of tools out there. Everything was fine for several years until the first winter after I insulated and drywalled. Everything rusted up due to the increase in moisture the dryer was injecting into the cold environment. now that the garage is heated, I am hoping that it won't be as bad because the relative humidity won't be as extreme.
Re: My results were not good
Bill Howatt
>I think one key to my setup working is the fan which dilutes the moisture by moving it out of the shop and into the entire basement. Also, if the furnace fan is running it gets some of it and distributes it around the rest of the house.
Bill
Marv
>Hi Terry,
I have a bathroom with an electric wall heater. When we take a shower and the heater is not on, the mirrors, window, everything is steamed up and wet. When the heater is on, no moisture. It's worse in the winter than in the summer.
This situation is similar to venting your dryer into your shop. The amount of moisture that exits your dryer will be in accordance with how well your washing machine spin dries whatever you have washed. Some things will get dryer than other things.
As a general rule, I would be trying to prevent any moisture from getting to my tools and machines.
I mention the heater, because that might be your answer to reduce the amount of moisture to a point where it won't effect your bare metal surfaces. It might not require a very large space heater and most of them will have a fan. Maybe having it set on low will do the job.
Anyway just some thoughts....
Marv
Re: Same here
Ron Hildreth
>I used to vent the dryer into my garage - same one that houses my Harley. After having to replace a lot of expensive chrome, I moved the vent to the outside. I'll never do that agian!
Ron in Iowa
Re: Humidity
>Humidity is the main factor. We used to have one of those fittings that allowed warm air from the drier vent to be exhausted into our utility room but ended up discarding it due to having too much humidity for the small area.
Don't see why not
Gil Jones on Lake Seminole GA
>The question sounds (to me) like Terry may just want to use the old electric dryer as a warm air supply in his shop, and not in conjunction with drying wet clothing. It would work, but I might worry about wood dust accumulation in /on the heat coils, or they may be self-cleaning via the red-hot coils. He might need to get a 240-volt thermostat (or a low voltage one and a load relay) to control the dryer. Any heat generated stays inside the shop, and not up the flue.
hb
HB
>Humidity will be an issue. It will condense on the first cold thing that it finds, probably the metal walls of the building closest to the vent.
I would also say that besides the lint ruining your finishes, it may ruin your lungs. It's never a good idea to inhale fine particulate matter, whether it came from a piece of maple or your blue jeans.
Even if you added a heater, all you do is increas the capacity of the air in the shop to hold the moisture in its gasseous phase. Instead of a general accumulation of moisture across the shop, what you'll find is some smaller areas where the moisture is concentrated.
If the shop is insulated, any breaks in that insulation will allow the saturated air to get between teh insulation and the metal shell of the building where it will condense and soak the insulation and, in a worst case scenario, create a mold bloom and corrode the building shell in that area.
And although this question was about an ELECTRIC dryer, attempting this with a gas fired dryer would add the risk of asphixiation of the building occupants.
I wouldn't do it in my shop.
HB
