Sorry I asked
>So the other day I needed a sheet of 3/4" birch plywood. I decide to go to Home Depot. I went early on a weekday morning to avoid the crowds and hopefully be in and out quickly. So I get to the birch ply and as usual I find myself casting off the first few top sheets as they were in sad condition. Finally I find one that appears reasonably flat and un-chewed up.
I pull the sheet out and get to figurin'..."hey, I have to cut this sheet down anyway so why not get it cut in half here...easier to manage". Well that seemed way too simple...until I made the effort to get it cut.
Earlier, when I was sorting through the birch ply there were plenty of slack-jawed orange vested kids wandering around. But when the time came for really needing assistance I swear the entire store was deserted. I was ready for tumbleweeds to roll by. So I press the distress button, next to the panel saw. That of course activated the lovely woman's voice "Customer service needed...saw area" I waited a while and nothing. So I press the button again, and again....nothing. Now mind you, I probably was the only customer in the store at the time.
Finally I walked up to the front where an orange vested woman was sitting, looking like she was supervising the battery display. I said to her "hi, I need a piece of plywood cut but can't locate assistance...mind if I use the panel saw myself?" Well, those must be the magic words. Suddenly a flurry of walkie talkie activity ensued between several orange vested people throughout the store. She indicated that there was only one guy in the store that knew how to use the saw and that he was on his way. One guy?
So I see an adult in an orange vest lumbering down the aisle towards the panel saw. "You the guy who needs something cut?" Now mind you, I am standing next to the panel saw holding a full sheet of plywood and there is nobody else in sight. "uh, yep" says I. "How do you want it cut?" I said "cut it in half width-wise? He gets a puzzled look on his face so I rescue the awkward moment by saying I want two 4'X4' pieces. Unfortunately that only created an even worse awkward moment as I could see the wheels slowly turning in his head trying to figure out if it was even possible to get two 4X4 pieces from a full sheet. Sure enough, he grabs a tape measure and measures the sheet to make sure. Meanwhile my eyes are uncontrollably rolling.
What ensued then was, by any description, comical as he attempted to set up the saw for the cut. The saw had been turned to make a length cut and needed to be turned back to do a cross cut. After much trial and error he figured it out, but not before knocking the dust collector hose off which retracted behind the saw frame. He performed a series of monkey-like manuevers to get the hose looped back over and reconnected to the saw.
Finally we get my sheet of ply on the saw and Mr. orange vest lines up the cut. He turns and says "do you want me to cut right on the 4' line?" At this point I wonder if I am on a hidden camera TV show. I said "yes...that'll be fine". So he pulls the saw trigger...nothing. Then he remembers he needs to activate power to the saw.
So there is a power box off to the side. But before he can activate the power he has to enter a security code into a key pad to the side of the box. You guessed it...he had trouble remembering the code. Finally, by some miracle and after several attempts, he entered the right set of numbers. Random luck I'm thinking. He activates the power which in turn activates a warning siren and a spinning red fire engine light. All features I presume were suggested by Home Depot's crack staff of lawyers...Dewey, Cheatam and Howe.
At this point I am taking stock of my life and pondering about how much of my life has just been wasted. But wait...there's more....
The guy proceeds to make the cut...on the 4' line. And as I watch I noticed that the saw blade leaves really ragged edges on both sides of the kerf. Side note...don't you think that Home Depot would have the sense to have a decent blade for cutting ply? I chose not to waste my breath by commenting. I grabbed my sheets and made a beeline for the checkout....and yes, the checkout girl was of course confused because only one sheet on my cart had a bar code.
I wish I had memorized the key code on the safety of that saw because next time I swear I'll show them what a "DYI Store" really means!
Tom
