A55 Smoothing Plane
Totally OT for the pilots and Rod *LINK*
Dan Donaldson
>Here is an interesting landing for you. Needs high speed connection.
Scary landing.
Re: Totally OT for the pilots and Rod *LINK*
>Yikes, I thought the runway in Oliver Springs here was spooky since you lose sight of the runway when crossing a ridge on downwind, then pick it up again as you turn to cut through a gap on final - got real interesting at the gap with a crosswind!
I can't even imagine threading and landing in the big rocks like that, even having to skim a ridge on final. Did you notice how much they had to fill to try to make a bit of a flat spot on the end of the runway?
Uffda!
Bruce, a MN Galoot
Sweet!
Rod Peterson -- Ormond Beach
>Well, not nearly as exciting due to the lack of Alps, but the runway at the old Dodgeville, WI, airport (since closed) had a pretty good slope to it—enough to give serious consideration to downwind operations. There was also a ravine and concomitant hill (not Alp) at the low end. I don't remember the length now—it was more than adequate for a 172, but I wouldn't have wanted to fly a C-97 in there…which someone did, and parked it outside the Don Q Inn, never to be flown again.
If you go to googlemaps.com, select Satellite, and type in this string (cut and paste to make sure you don't introduce any errors—the leading "+" sign is important): +42� 59' 43", -90� 08' 35." then click <Search Maps> you should come right out at the Dodgeville airport. You can still make out the "12" on the NW end of the runway, but all other markings (including the "X"es normally painted on closed runways) are gone.
If you look down at the lower right corner, the orange roofed building is the Don Q Inn, and if you move the map up a little, you'll see the C-97 sitting along the main highway in front of the inn. Pretty impressive.
I wish I'd been there for the landing. I'm told there were great clouds of dust when the pilot put the props of those great R-4360s in reverse. The low end of the runway is the northwest end, so he landed southeast which necessitated a tricky approach over the hill defining the west side of the ravine. Nothing near so dramatic as Courchevel, of course, but I doubt they're putting four engined, 100,000 lb airplanes in there, either.
In any event, thanks for the link, Dan. There are tons of interesting things to see on YouTube. I spent an hour or more each the last couple of nights in the music area. Last week I found a video of an F4U Corsair lighting off its R-2800 after watching an AD taxi in. All that violence under the cowl is awe inspiring…and impossible.
Rod
M. McNamee
>Rod,
I sent this story and information to an old Lockheed engineer I work with. He enjoyed it and shared it with his son who flys transports for the Airforce. The question I got from this guy is when did the C97 land and why?
He also said the C97 was a fat fuselage B29. Gave me, a non airplane guy, a perspective on the size of this plane.
C-97 stuff
I found the answer here.
Undercarriage, wing, and tail surfaces are indeed straight from the B-29, and the fuselage is sort of 1½ B-29 fuselages. That description is made more clear by visiting this Boeing 377 website. The C-97 is just the military version of the 377, and the KC-97 is the tanker version. The Illinois and Wisconsin Air National Guards were still flying KC-97s out of both ORD and MKE when I was working traffic in Chicago—I think the Illinois wing transitioned to KC-135s in the late '80s, and the Wisconsin wing may still have been flying them when I retired in '97.
Here is a modelmakers website with a little background on the 377 and links at the bottom of the page to C-97 and KC-97 models for detailed views of all.
As an aside, the B-50 which carried the X-1 aloft was another B-29 variant.
Rod
