Have a question? Ask Woody!
Glue Lines from Tightbond III
Jeffrey D. Rose
>I am making a chest of butternut and walnut. I cut full dovetails that are seen. They fit very well, but I glued them with Tightbond III. I was the only glue I had on hand. Well, it seems that the glue show slighty white in all the dovetail joints, not a alot, but enough to drive me nuts. Any ideas on covering that glue up? I plan on finishing it with clear varnish, but I doubt that will change the color.
TIA
Jeff in Iowa
PS I have a weather monitor on my house, right now it is -1 and the wind is blowing at 46.7 mph...yup that is right that means -50 wind chill, wow I wish I had a wind break right now.
Re: Glue Lines from Tightbond III
Oops Titebond, not Tightbond
Jeffrey D. Rose
How odd
Dave Bair, Eaton Rapids, MI
>I don't have an answer for you, but I use Titebond III all the time and it always dries dark, never white. That's why I use it unless I'm doing pine or maple where I go back to plain Titebond.
Sawdust Everywhere!
>Jeff,
I use a lot of TBIII in my unheated garage too and what happens is that the glue will turn white if it FREEZES BEFORE it cures fully. It has happened to me many times when I am too lazy to bring my wood pieces into my heated home to glue up.
I think it has to do with your home in -50 windchill temps and your pieces not being at a temperature higher than 47 degrees when it is curing. ;)
HTH
Jeffrey D. Rose
>I would agree with the too cold garage part, but I have radiant floor heat that keeps it right at 50, maybe that is to close to the 47.
Jeff in Iowa.
Howard Acheson
>It sounds like what is called "chalking". That is indicative of the adhesive being too cold to cure. If that's the case, your joints are going to be very weak. I would cut the joints and reglue.
