A55 Smoothing Plane
RE: Using MDF core as an armoire base
al
>I am making a good size armoire for my daughter. it will be 77" high, 46" wide and 24" deep. Part of it will be used for holding a TV. I am using African Mahogany with a plywood core for the sides and back and machining 4 quarter African Mahogany for the door styles, etc. When loaded it will weigh around 450 pounds.
I have a piece of 3/4" walnut mahagony with a MDF core from a previous project. Is this strong enough to use for the bottom? It would be dadoed 3/8" into the sides and supported by 2-3" square legs inset 2-3".
Re: RE: Using MDF core as an armoire base
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>I don't mind using MDF for core for veneering, but I draw the line at using it for structural parts for furniture that will be moved around. It will not stand up to being moved around, and taking a jolt will break it.
I would advise against using it here if I understand what you are planning. Young people move around a lot, and you have to know that someone along the way is going to bump or drop a heavy piece like this, and your daughter will want you to fix it. How will you fix this part if it breaks out?
Kris Lasure
>I just finished an armoire about the same size you mentioned. For the bottom of the case I used a torsion box design. Basically it is two sheets of 3/4" ply spaced apart about 6". In between these two sheets are two vertical "joists" of 3/4" ply that run front to back. These are dadoed into the plywood bottoms, glued and screwed. Like you also mention the plywood shelves are let into the case sides in dadoes, glued and screwed in place.
I put in a 32" tube TV and have absolutely no sag. A good way I checked this is that my doors are inset and the reveal around doors and the case remained the same prior to and after the TV.
The face frame is also glued to shelves and the back is screwed into the shelves which help a lot as well.
Hope this helps.
kl
