Solids in a can of Deft
Tom Dunlap
>I have a brand new can of Deft clear finish that I opened today. The solids have separated out from the liquid. It looks like a peanut butter container :)
Can this be mixed and used or is it trashed?
Would I be OK taking it to the paint store and have them put it on the shaker to mix it up?
Thanks!
Tom
Re: Solids in a can of Deft
Re: I'd stir it....
>to see if it started to redissolve the solids.
Steve Schoene
>Deft makes a number of products, although their brushing lacquer is most widely known I think so I assume that's the Deft you mean.
I can see solids separating if it is a satin finish where the "flatting" agent can settle. But otherwise it is an evaporative finish and the resins ought to be dissolved in the solvents I would think.
Lee Grindinger
If it's nearby
Lee Grindinger
>If it's nearby go back to the paint store and ask them to put it in their stirrer. Don't let them put it in their shaker as this fills the finish with air bubbles. Stores that sell paints have a second machine that swirls the can rather than shakes it. Make sure you told them you opened it, they will want to reseat the lid to avoid a potential mess.
If it's the Deft brushing lacquer it should all dissolve nicely as the others have said. If it's a different product, like poly, it's a return item.
Lee
It's normal
Lee Schierer - McKean, PA
>I've used Deft for over 20 years. Its normal on semi-gloss or satin for the solids to separate. Stir it gently until the color is uniform and use it. If you read the can it says to stir before each use. As others have said, resist the temptation to shake the can. It takes forever for the bubbles to separate out.
Be sure to use it in a well ventilated area. The fumes are pretty strong. You can apply the finish in an unheated space. It just takes a bit longer to dry. I've applied it at 25 degrees with no adverse affects. Deft agrees with the cold temp applications.
Lee
Trash
Tom Dunlap
>Thanks for all of the tips.
Before leaving home I called a couple of paint stores. They didn't have paint stirrers only shakers. Then I went to the shop to see if I could stir up the solids. When I poked at the gob I found that it wouldn't break up. Instead of wasting time I decided to just get rid of the can. Fortunately it was only a pint.
Tom
Brrrrr !!!
Steve Schoene
>You may find no adverse effects from applying finish at 25� but that's just a little cold for me.
