Staining help needed - two-tone cabinet door
Cody Lewis in LV
>I'm making a couple cabinet doors and I'd like to have the panels a lighter color than the edges (rail and stile). I was planning to make all the necessary cuts, then do all the staining on the disassembled pieces, then glue it up for a finished product. The problem is that I'd really like to route the edges of the assembled cabinet door to match the edges I've done on the rest of the project, but this can only be done if all the assembly is completely done, and this obviously will create an unfinished edge (raw wood).
So here's the question: If I were to assemble the entire cabinet door before staining, and if I taped off the panel, would the tape prevent the dark stain from getting to the panel?
Seems like the dark stain would bleed thru the tape and "infect" the panel, making it impossible to leave it lighter than the rest. Please give any and all suggestions.
