How to splice 6" wide birch valance material
Geoff (in Madison)
>I need some design help.
I am fabricating and installing a 6" wide valance made of birch. One wall has a bank of windows that is 16' wide. The longest board I can get is 12' long so I am going to have to splice the boards.
I know I can just bevel the ends and try and hide the joint, but are there any joints that I might use that are clearly visible, but are attractive and fun to look at.
The double-block wedged reverse bevel scarf joint used in the Gamble house may be overkill (and out of budget), but other suggestions would be most appreciated.
Thanks,
Geoff
Re: How to splice 6" wide birch valance material
Sue McLam in Orange, VT
>Geoff,
Off the top of my head - how about splitting up the valance at each window section and put in a vertical piece that aligns with the window trim. You could attach all the pieces simply with pocket screws or go with mortise and tenon. Sort of like this:
Sue
NickB
>I'd develop Sue's suggestion a bit. You need to add a design element to hide the joint(s)-it could be a key, rosettes, or any kind of thing that will go with the rest of your trim package. The element could be over each window, or just in the middle. Get out your pencil and sketch a bit-see what looks good.
Hope this helps,
Nick
