Fireplace Surround
Ray Johnson
>I am building a fireplace surround to go around our gas fireplace. So far, I have the framing done and the wallboard "tacked" in place. The surround is almost finished but not shown in the pictures. About 18" of wallboard will show on each side of the surround. That will be painted. I am building the mantle also.
Behind the wallboard on the left side is a gas shutoff valve. There is also one within the fireplace itself. I want to have access to the shutoff valve that is behind the wallboard.
One option I am thinking is to built in speakers along each side of the fireplace. They would be about 12" from each side of the fireplace and enclosed to eliminate as much heat from the FP as possible. That would give me the access to the valve, wiring, etc. Or I could just install some vent or screen panel to allow access.
We will most likely put an LCD TV above the fireplace. For that I need access for electrical and electronic wiring. I could add a small access (door?)behind the TV when we do the install.
Any suggestions as to installing speakers and/or access panel of some kind.
Thanks, Ray
