Bessemeyer fence
>I have a friend who wants to upgrade the fence on his Powermatic 66. He has a 28" table. He said his saw is called the Home version of the 66. Does anyone know where to find that. I don't have anything in my catalogs.
Bessemeyer fence
Re: Bessemeyer fence
Dan Donaldson
>I believe that most fences are relatively generic as to mounting. The most you should have to do is drill a couple of holes.
Miter Slot Notches
Marvin Horn
>The mounting angles for the Beis have notches which line up to provide clearance at the miter slots. There is a slight difference among manufacturers on miter slot spacing. Worst case, is that you cave to enlarge a notch.
Angle grinder
>I replaced the rear rail on my Biesmeyer fence with a larger piece of steel, and quickly discovered how handy that notch was :) A hack saw and angle grinder quickly made a similar notch in my new rail :)
Happy Woodworking!
Re: Angle grinder
>I put a Biesemeyer fence on my ancient Rockwell Delta TS a few moths ago. The portion of the angles that was cut away for the rails was fairly wide. My guess is that it will work. If not, all you have to do is cut or grind it away. Not really a machining operation, just stock removal.
Re: Angle grinder
Ross
>The standard Biesmeyer rails work just fine on all of the PM saws, just like they do on the Deltas.
