Electrical Gremlin Question
Nat Robison
>I know a bit about wiring but less about troubleshooting problems. I finished a portion of my basement over the past year and just encountered an electrical hiccup this past weekend.
One of the rooms is serviced by a single 15-amp circuit (14 ga. wire). The wire comes from the main and feeds about 6 outlets before going to a switch and then to a couple of recessed lights. I flipped the light switch and no light. I checked that the breaker hadn't tripped (it hadn't). I decided to check the outlets by plugging in a fan to see if there was power at each outlet. The outlets were all fine but at the 4th outlet, I plugged in the fan and the lights came on at the same moment (I had left the switch on).
Everything looks tight in the switch box. Any thoughts as to the problem and where to look next?
