Bessey K-Body Grip Slip Solution?
John Hollaway
>Like many others on this forum I am very fond of my Bessey parallel jaw clamps. The only negative I've found with them is the slippery grip when tightening. I can imagine several possible solutions, but I would also be interested in hearing from others who have already modified their wooden grips. Thanks.
Re: Bessey K-Body Grip Slip Solution?
Art Liebeskind
>Rockler has a rubber grip that slips on the handle. It really works
Art Liebeskind
Michael Wangler in Rochester, NY
>John,
I always make sure my hands are really dry before tightening up the clamps, but based on Arts responce I wonder is you might be able to use an old inner tube from a bike. Cut a 4" section, clean out the powder on the inside of the tube, spray the grip with a bit of hair spray and slide it on. The hair spray will facilitate easy application, but then it will dry and hold the rubber. I used to used this in a bike shop for putting grips on the handlebars.
I'll have to try this...
Michael
Scott Banbury
>I've taken a block plane to the handles of a couple of mine--a few shallow facets imparts a lot of grip.
Re: Handle wrap on clamps
Henry (Raleigh NC)
>I don't have Besseys, but just last night I dealt with this issue. I have a variety of F style clamps with fairly small diameter wooden handles that are somewhat slippery. Having lots of old bicycle inner tubes around (also useful as band clamps), I wrapped the inner tube around the handle fairly tightly and then tied it off (i.e. I wasn't sliding the tube down over the handle, the size was mismatched). This both improved the grip tremendously and served to increase the diameter of the handle, making it much easier to grip.
I'll have to see how well this handle wrap stands up over time; I may have to use some sort of adhesive to keep it there, or to tie it off. Right now however, they are much easier to use.
Henry
Dave Bair, Eaton Rapids, MI
>I use a pair of nitrile-faced gloves; they fit tightly, deflect splinters (white oak, ya know) and give me a good grip on a variety of objects, including the Bessey handles.
Steve Schoene
>I suspect there is a reason for the straight handles. With more leverage on the handles you could be getting closer to breaking something in the mechanism.
Alan in Little Washington (NC)
>In one of the WW mags, someone described how they used a router to add fluting to the handles.
Mud Gloves!
>Get a pair of "Mud Gloves". They are those knit garden gloves that are dipped in grippy rubber. They'll give you a real good grip on clamp handles. They can be found at garden centers.
Tom
Walt Turpening
>John,
Go down to your local bicycle shop and get some of the handle bar cloth tape. It is adhesive backed. Overlap about half the width of the tape. When it wears rewrap. When you are bored with the color change it.
DizD
>I bought a can of Plasti Dip (tool handle coating) and dipped all my clamp handles - been over a year now and its still holding well. Hint: if you get a can use it in a day or two. DAMHIKT.
