OT Something Stinks in the shop
Dustmaker Mike
>well my shop is in the basement along with the washer and dryier. The LOML was washing cloths this weekend while I was working on setting up some equipment. The washer stopped its wash cycle and started dumping the water. Shortly there after there was a sewer smell. The cloths come out clean with no order and no place in the house just the basement. So now I am wondeing is the washer pushing to much water for the drain and empting the "P" trap, letting the sewer gas back in? I really don't want that smell getting upstairs into out normal living space, so I need to stop it soon. Any ideas cause I just plan don't like the smell
Re: OT Something Stinks in the shop
>Gravity keeps the trap full, regardless of how much you into it. Sounds like you have a back-up. Tank ot Sewer? If tank, get it pumped out and flush all of your lines. If sewer, call your township and complain of the gas. You still may need a plumber or snake-job.
mm
>In addition to what Mark said, check your vent pipe. If your vent pipe is clogged or plugged, it can cause similar problems - inappropriate draining of your trap.
The good news is…
Rod Peterson -- Ormond Beach
>…that smell tends to be transitory, and once the source is eliminated will disappear, even if traces do make it up into the living quarters while the source is active.
Rod
who's had too much experience with odd house odors.
steve mackay
>I just cleared up a smelly for a freind. All it was was a loose cap on the clean-out port.
You Should Have Beden Here Last Night
>Good Morning Mike,
Before all the boys got here for the Family-dinner-party/Drink-up-Dad's-beer-activity, I began testing stain and dye colors to match some modifications to #1 son's night stands. I found some old mixed up jars of water based aniline dye, opened them and dipped a sample of fluid to apply on a cherry test piece. The dye water had become putrid. My smeller doesn't work very well, but the aroma nearly knocked the boys over as they entered the shop. First thing today is get rid of the old dye and mix batches of new stuff.
George
Re: Old Can Still Be Good
>George,
You can extend the life of your solutions by adding about 10% DE-natured alcohol to your mix. Won't effect the dye and acts as somethiing of a preservative. I have water-dissolved dye that is more than 2 years old and still fine.
There are a host of one-liners I could add here, but I'll leave it to you.
Check the drain in your shop!
Lee Schierer - McKean, PA
>If you have floor drains in your basement that are connected to the same sewer as the washing machine then the traps in the floor my have dried out. This is not an unusual situation where floor drains don't get used, the water in them dries up and lets the sewer gas escape. Pouring a gallon of water down each one about every 2-3 months should take care of the problem.
Lee
AC Unit Too
Tony - Memphis
>We had a weird one where once in a while, I would hear a strangle gurgle and then smell sewer gas in the bathroom. Long story short, I figured out it was associated with the heat coming on. Our AC unit had a drain with a trap (drained to sewer) and during the winter (no ac), it would dry up and the system was pressurized when the ac fan came on and it would push out some sewer gas. So, every once in a while in the winter, I would remove the coupler and pour some water down into the trap.
Tony
Thanks All
Dustmaker Mike
>well I don't have a low point drain in the shop. I have a sump pump hole and that is pretty dry. This only seems to happen with the washer draining. I did add alittle water to the furnace drain to see if maybe that would do it. All the plumbing works correctly. I am haveing a Hot Water heater installe in a month or so. I will check with the plumber and see what he says. I have a Home Warrenty that should cover Sewer cleaning so if that is it I am covered. Again Thanks for the Information.
Re: Check the drain in your shop!
Pete Stahl
>Like Lee said. We had a check list at work for this reason when I worked in the lab. We had a lot of small cup sinks that we didn't use but were still active. I also have a powder room that gets little use and make sure some water get down the drain at least once a week.
