OT-Home Electrical System Question
Mike Baratta
>Hi all,
Has anyone ever heard of or experienced a situation where it seems lightbulbs in your house don't last nearly as long as they should? I've been in my current home about 6 months. It was built in the 70s with 200A service and a breaker box. I may be imagining this but it seems like I am always changing bulbs. If this is plausible what could be causing it? I know there are a couple of circuits that are overloaded but I believe that stems from amateurs adding lights and such over the years to an existing line without regard to the total current drawing on it. For example I can't vacuum in the living room with all the lights and TV on or it will throw a breaker - ugh!
Any help as always is appreciated.
Mike
West Chester, PA
Re: OT-Home Electrical System Question
Ken Garlock, Collin County Texas
>Hi Mike. I don't think you are imagining the shorter life of the bulbs. If you look at the label on the bulb it will say xx watts and 120 volts. If you have access to a voltmeter, take a reading on your line voltage at an unused outlet. There is a good chance that it will read in the 125 to 130 volt range. The over voltage will shorten the bulb life. Go to a lighting store and buy 130 volt bulbs. I can't say for sure, but compact florescent bulbs my last longer.
It might be a good idea to have your wiring examined by an electrician. You may save yourself from a fire.
Happy sawdust,
Ken
Chuck W
>I'll second what Ken said. I have seen the results of some wiring done by the well meaning homeowner with no idea how circuits and electricity works. A mess to say the least. Sounds like you have an overloaded circuit soemwhere.
Bill Howatt
>An overloaded circuit won't cause bulbs to burn out quickly.
You may have too high voltage being supplied to your house but the spec is actually pretty wide so the power company may not do anything about it depending on the voltage.
The other thing is a bad neutral connection at the panel or pole. This causes the voltage on one side or the other to improperly divide the nominal 240V supplied. The amount of 120V load current on each side of the neutral will determine what the voltage split is rather than it being held at half of the 240V supply as it should be. You can check this by measuring the 240V supply and then checking outlets that are connected on either side to see if they are half the value.
If you don't feel confident doing this - get an electrician.
Bill
John McGaw
>To what the others have posted about higher-than-optimal voltage I'll add two other problems I've seen: vibration and temperature. The first is pretty self-explanatory -- the filament in an incandescent bulb gets pretty limp when working at full temperature and if you shake it while it is in that state it can fail early. The latter is something that seems counterintuitive since the lamp is already working at insanely high temperatures but I have seen lamps in tight enclosures fail early, probably more from corrosion/arcing of the base than actual filament failure.
>Another thought is widely varying voltage.
I've had this at a former work place rather than at home. We put a "recording" voltmeter on some of our circuits and found that they were varying from 105 to 120 V. Equipment and lights on these circuits seemed more prone to failure.
Bill Roland (Mt Juliet,TN)
>I had the same problem using the vacuum in a certain room, it would pop the breaker. I finally checked the circuit breaker panel and found that the wire for that breaker had not been tightened properly. Over the years, about 4, the wire had got hot and this caused connection to get worse. I replaced the breaker and cut off the discolored wie and now I can vacuum in that room. Pull the cover off you panel and look for a discolored wire on that breaker.
JerryBurns
>Mike
Have an electrican check the neutral wireand both feeders wires at the main you could have aluminum wire heating cooling causes the wire to loosen up over time
as the house was built in the 70s I would think this could be your problem. I have seen this 10 -12 times on service up grades I have done on houses that age in my area.do your lights fliker when your heater starts or frig then this could be part of the problem
Yup!
Rick Christopherson
>The greatest cause for premature bulb failure is vibration. You may not notice the house shake when someone walks upstairs, but the bulbs sure do. The voltage variation on a whole house is not significant enough to have a noticeable effect on the bulb life. If you were experiencing every single bulb in the house having a shortened life, then this would be more likely. If the bulbs are burning out in specific areas, then vibration is the more likely cause.
Several people have commented about having a floating neutral, and while this is a real situation, premature bulb burn out is not the first symptom that you would notice.
bad neutral
JohnKJordan in East TN
>>...The other thing is a bad neutral connection at the panel or pole.
I found this problem in a friend's shed/shop just last week. He had many electrical problems in the building. All connections in the box were tight.
I watched the voltages on both legs varying when he turned on various circuits. I found a loose connection where the neutral line from the pole connected to the panel. Sparks came from that connection when loads were applied to some circuits.
The bad thing was, since it had been arcing for some time, the connector threads were welded together and could not be tightened and the wire was too short to reroute to another connector. I ended up reversing the neutral bar in the box so the wire could reach to a second large connector on the other end. All is now well.
The advice to occasionally check the tightness of all connectors in the box is good, but in this case it didn't help since that one screw was welded tight. Wiggling the wire near the connection showed it was loose. (Don't try this if you are not experienced with working in a box - even with the main breaker off.)
Mike Baratta
>Gents,
All good points. This mechanical engineer will learn some things about electrical yet.
I just checked many outlets on different circuits with a voltmeter. They are all pretty much right on 120 +/- less than 1 V.
I'm going to call an electrician. It's worth the piece of mind to get things checked out. I suspect the vibration is the primary issue here but we'll check out the tightness of all the connections at the box as well as the neutral bar.
Thanks for your help.
Mike
Try a different brand
Lee Schierer - McKean, PA
>Personally I've had better luck with longer life from Sylvania incandescent lamps than the other leading brands. I've also seen better life from name brands rather than generic lamps. LOML bought some no name bulbs and they didn't last long.
Try a differnt brand of bulbs.
Pete Stahl
>My front lights wouldn't last very long so I bought a dimmer and just turned them down a touch. Seems to have done the trick. Maybe when it gets warmer out I'll check the voltage out of curiosity. A dimmer will also help a light last longer for most bulbs. I think I have almost as many dimmers as regular switches in my house. If you install dimmers, double check connections and make sure ground if far from any connector. Dimmers short out easy, DAMHIKT.
