Re: Sorry, crown molding ( again ? ) . . .
Mark in Whitby
>Obviously you will be able to find ceiling joists running perpendicular to the CM to nail into on two walls, and the wall studs to nail into for ALL walls.
For the two walls where the ceiling joists are running parallel to the CM and likely not where you need to nail the crown up into, you can still nail into the ceiling (reccommend using a nail gun with 2" brads that will bend and curl a bit when entering the moulding and drywall ceiling drawing the moulding somewhat tighter and giving you some grip.
Make sure on these parallel joist walls you catch every single wall stud you can, and the corners, and that the moulding is properly postioned and held tight to the ceiling when nailing the into the wall studs. If it is properly positoned to begin with the nailing into the wall studs and ceiling will help hold it tight.
I have also used a light bead of caulking along the top of the CM to stick it a bit to the ceiling before nailing for added adhesion.
Don't use to much or it can disorient the correct position of the moulding.
Over the last 4-5 years I have done 6 rooms of my house in varying styles of 4-6" pre-primed MDF Crown this way, and finished it off by caulking the top and bottom of the moulding and all corners before painting, to fill any gaps caused by ceiling irregularity or slightly crooked walls.
I have tight inside joints (coped) and tight stable outside corners with no signs of movement or gapping.
As far as I know, this way may be the totally wrong way to do it ....but the results speak for themselves and have held up 100%.
Main thing is I have never seen any gap issues at all espesscially from not being able to nail directly into a ceiling joist on those two walls.
Good luck the look is really worth the effort it when it's all done.
Mark
