OT - rust on old shotgun
Joe in a Cleveland Suburb
>Hi all.
I have an old Remington shotgun my dad gave me years ago. His father gave it to him when he was a young boy. Late 30's maybe?
Anyway, I never use it. Never hunt or anything. I took it out of the case the other day and noticed there is spots of rust on and in the barrel.
Is there a specific way this should be cleaned to remove the small areas of rust, to help prevent further rust, and to store it properly?
Thanks for any advice on this!
Joe
Re: OT - rust on old shotgun
Randy Johnson Connersville IN
>For starters, never store a firearm in a case. It will rust every time.
Depending on how bad the rust is, a light rubbing with fine steel wool saturated with light oil will usually remove it. Heavier rusting will require harder rubbing. I've never had to work very hard at removing rust because my guns never got past the (very) light stage.
Do the same with the inside of the barrel but use some type of gun cleaning solvent instead of oil.
After everything is nice and clean, wipe it dry. Then, since you say you don't shoot it, coat all metal parts with RIG (brand name)and store the gun where it can have air circulate around it. The back of a closet is fine, just don't put it back in the case.
Before most of my guns walked out the door back in 99 I did the Rig thing with anything that wasn't shot on a regular basis. Although there are differences of opinion on the wisdom of it, I even put Rig on the stock.
The only long gun I ever saw again (five years later)would have had this treatment and it didn't have a speck of rust on it. I'm sure it didn't get much care during its travels so the Rig treatment must work pretty well.
Larry Clinton At Frankfort (Central)., Indiana
>I agree with everything Randy said. However I use "Sheath" gun preservative instead of "Rig". I have about 45 guns in gun safes and other areas of my house. None have ever shown any rust after several years of storage. I have used the "gun cold bluing & browning" coating on a couple of old guns that had very worn barrels. It did work but I didn't like the looks so had the guns professionally hot blued. You may want to have the gun blued. It restores it to new condition. In this area the cost ran $30 for one handgun and around $50 ~ 60 for a rifle. This was about 15 years ago so I am sure it is higher now.
Gene Gauss
>I recently (about two years ago) had a Weatherby Mark V rifle reblued because of a deeply rusted handprint (not mine - keep your sweaty hands off my guns) on the outside of the barrel at a cost of either $200 or $250 - I'm not quite sure which. I've removed VERY light rust spots on the outside of a barrel, for example from hunting on a rainy day and being too tired to remember immediately on coming in, with an oily cloth patch. I suggest you try that first before going to anything more abrasive. Fine steel wool and oil would be a reasonable next step.
