OT: Electrical subpanel
Joey, N.C., CT
>Can I use my 20 amp, dbl. pole breaker, which is currently dedicated to my 12.8 amp 3hp table saw, as a subpanel feeder breaker? This will enable me to add 2 120 amp breakers for additional circuits as well as the saw.
Why not add the 120's to the main or a 30amp 240 subpanel feeder for a new panel? Because my main panel is so old, I can't find new circuit breakers. Thanks Joe
Re: OT: Electrical subpanel
Randy Johnson Connersville IN
>What kind of panel do you have now?
Some breakers,, like the old ITE Pushmatics, are expensive and hard to find but you can find them. In some cases brands are interchangeable.
I don't see any point in using a 20 amp breaker for a subpanel feed. The smallest I would go is a 50. You may have to bite the bullet and install a new main.
Re: OT: Electrical subpanel- Wadsworth
Joey, N.C., CT
>Ever heard of it? I like your suggestion to replace the main. I was lucky enough to salvage a Murry with a 200 amp main breaker and lots of circuit breakers. I would pick up the additional circuits I need.
I only have 100 amps to the house, so I would need to buy a new 100 amp main breaker or get the electric co. and the town involved.
Thanks for your reply. Joey
>You are right. Wadsworth panels went the way of the buffalo a long time ago. They were a brand of breakers that failed financially and you will be lucky to find replacements out side a museum.
You would be better off installing the new panel. You might want to check first and see if Murry is still viable in your area. I have not seen a new one in a long time. Generally, the Electric company will do their part of the work for free, at least locally.
And, You can set a sub panel even if you powered it with a twenty amp breaker. Then you can pull any number of circuits out of it. This may not be precisely correct, or the best practice, but the worst that would happen is that you would trip the breaker once in a while. In a one man shop, that is somewhat unlikely, unless you are in the habit of running several tools at once. (Now that I think of it, I do run several tools, the TS, the Dust Collector and sometime the Air Compressor, but is you have them on separate circuits now, it would still work.)
As a Home Inspector, I would recommend you set the new panel and do it right. It will increase the amperage of your system and the resale value of your house.
Re: WOW!
Joey, N.C., CT
>Somebody actually understood me and replied eloquently.
I should do it right and bump up to 200 amps. Do I need a permit and an inspection for that? Thanks, Joey
Gene Gauss
>Not to disagree with Barry re. the wisdom of replacing your existing panel with a larger capacity unit of current availability, a quick search of the Internet shows a fair number of Wadsworth breakers available at not too outrageous prices. My last purchase of breakers for my old 200A Wadsworth panel, which was within the last 7-10 years, was from a local electrical supply house that had a few replacements made by someone else in stock, and were able to order some for me.
Gary Evans Tallassee, TN
>Hi Joey,
I also have a Wadsworth panel and need to do the same thing you are talking about. While the box and the breakers are "obsolete," they are still available here locally. Only problem is that they are $100 each, regardless of amperage. I haven't shopped the internet yet.
My plan is to buy the largest 240 breaker that I can get (hopefully 100 amp) and use that to feed my subpanel. Around here you have to have an electrical license to replace the main panel if the meter has to be pulled, because a re-inspection is required. I don't have the right ticket, which is why I'm going with the sub-panel. No inspection required if the meter doesn't have to be removed and replaced.
There are a couple of brave souls around here who will change out a panel with the big wires hot, but I'm not one of them.
Gary
Yes, permit & inspections required........
richard jones
>Anytime you change the service, at least here in VA, you are required to obtain a permit. The two power companies here in my county will not (well sometimes I have to call the boss and fuss..........) set a meter unless it's approved by my dept., unless of course it's for ag. purposes....... Problem with NOT getting a permit, aside from the obvious, is that if something happens and your insurance company gets involved, they may not pay............. Your nickel, as they say.
rich
Re: WOW!
>I did not do any research on whether Wadsworth Breakers were still available or not. Or if Wadsworth made more than one style and if so, were the ones you need still available. Notice, I said "Went the way of the Buffalo". The buffalo may be making a come back, (or are those bison?), but Wadsworth will not be coming back. You may indeed be able to buy replacement breakers on the internet, but how long are you going to drag that buffalo around?
If you are temporarily hooking up that sub panel and you will be happy to pull it out when you move to your next house, go ahead, but you will still be selling house with an outmoded archaic system in it. If your Murray panel is serviceable, you can probably find an electrician who will install it for you for $500, More or less, and it will actually increase the value of your house. Since the construction industry is slow right now, you may be able to shop around and get this done very reasonably. Its a choice.
And, yes, get the permits, if for nothing else, to keep those bargain electricians on their toes.
PS. The cost may vary widely, depending on if the job is simple or wildey complex. It could involve pulling the existing panel, sticking a new 200 amp cable less than five feet long through the wall to the new meter, (simple) to setting a new outside service disconnect, new meter, new sixty foot long four conductor cable, to a new panel (not the Murray), and on and on. Check it out before you take the leap.
What happened to the buffalo?
>"...went the way of the buffalo a long time ago..."
What happened to the buffalo? They're not extinct, are they? Althought I never eat them, I see places all over town selling buffalo wings.
Happy Woodworking!
Re: What happened to the buffalo?
>My point exactly. Not extinct, just nearly extinct.
I just found out that I was wrong about the wings. I thought they were buffalo wings because they were bigger than everybody else's wings. Not so. It's because somebody claims to have invented them in Buffalo.
The Anchor Bar
>The Anchor Bar in Buffalo claims credit for inventing the buffalo wing. Many is the time I sat in their crowded bar/dining room and feasted on a double order of suicide wings. I even had them FEDEX wings overnight to me when I was on the road in the 80s. The wings were still warm when the driver arrived in the morning. MMMMM!
Re: The Anchor Bar
Jim Shaver Oakville, Ontario
>Funny one Ellis,
It's been a few years since I was there, but always on the list. I used to get there more often back in the 80's as well, usually on a weekend where there was a Montreal game in Buffalo at the Aud.
Twice I have had new tires installed at Dunn Tire across the street from the Anchor Bar, a great place to kill some time waiting and eat some great wings.
Now you got me thinking..
Take care,
Jim
