Arbor Nut
Arbor Nut
Arbor Nut
Don Gallaher
>I lost the arbor nut on my table saw. I found a nut a hardware store that is the correct size. Would it be safe to use it? Thanks
Re: Arbor Nut
Re: Arbor Nut
Bruce, a MN Galoot
>Don't know why not. Is it a left-hand thread?
Re: Arbor Nut
Backwards thread?
Re: Arbor Nut
I'm guessing not
Neal in San Jose
>When you say "right size", what do you mean? All of the table saws I've owned (3) have had square threads on the saw arbor. These are the large, massive square looking threads that don't resemble the pointy threads you see on a bolt. A threaded nut from a bolt might screw on, but the pointy threads are WAY weaker than the massive square threads. There are also more than one square thread type; Acme is one standard geometry, there are many others, so just because you got a nut from the borg with square looking threads, it still might not be the right one.
On something like this, where safety is possibly going to be compromised, I'd do everything I could to make sure I got the right nut. Start with the original manufacturer - these things get lost all the time, so I'm sure most distributors and manufacturers keep them on the shelf.
HTH Neal
Re: Arbor Nut
Acme Threads
Lee Schierer - McKean, PA
>I agree. Most table saws use what is commonly referred to as an acme thread on their table saw arbors. Most hard ware stores would not carry such a nut.
Lee
Re: Arbor Nut
I don't think so!
>I don't think so Mark!
Table saw arbors are all right hand threads. A left hand thread might loosen when the saw starts. Single phase motors generally run clockwise and the blade also turns clock wise when viewed from the pulley end of the arbor.
Lee
Re: Arbor Nut
Not always
Larry Marker
>Right tilt saws may be right-hand threaded, but left tilt saws are left hand-threaded. The threads are always such that the nut tends to tighten when the balde spins, but left- and right-tilt saws have the motors mounted on opposite sides of the blade, so the shafts turn in opposite directions.
Larry
Re: Arbor Nut
Re: Arbor Nut
Steve Kay
>The nut you bought at the hardware store may fit, but the precision of the threads-not the pitch, but how precisely they are cut-may not match the original. Also, the flatness and squareness of the face of the nut is not likely as precise as the factory nut. Both of these variables may affect how evenly the nut clamps up the spacer and blade. A poor fit may lead to uneven cuts and/or excessive vibration.
My 2 cents.
Re: Arbor Nut
Think of it as an opportunity to
Garrett in Victoria
>buy the Delta Arbor nut set and never drop one again. The larger nut can be completely undone without its falling into the saw cavity, and the smaller one is for dado sets. Beautifully designed and machined. They are worth the cost.
Cheers, Garrett
Re: Arbor Nut
Re: Think of it as an opportunity to
John Ballance
>I think the Delta Arbor Nut Assembly is no longer available -- can't find it on the Delta site, nor anywhere else.
Had a left tilt assembly that failed internally, and would like to get a replacement of the flange/nut assembly.
Right tilt part number was 36-659.
Left tile part number was 36-660.
I'd appreciate if anyone knows where to find a left tilt set.
Re: Arbor Nut
Re: Mark is correct
Brian in Brighton
>On my Delta contractors saw the thread is an 11/16-12LH left hand thread. I have a spare nut, if you need one for this model. E-mail me and I can drop it in the mail to you.
Brian in Brighton
Re: Arbor Nut
Rick L
Re: Acme Threads-not true at all
Rick L
>Most saws do not use acme thread. Left and right hand threads depending on the tilt style. Nut always comes loose in direction of rotation. All saw arbor nuts are self tightening.
Re: Arbor Nut
Woodcraft
Art Silva
Re: Arbor Nut
Re: Woodcraft
John Ballance
>Art, I'd appreciate a link at Woodcraft. My search of the Woodcraft site came up blank for the left tilt arbor nut with captured washer.
Thanks.
Re: Arbor Nut
Re: Delta Arbor Nut
John Ballance
>Never mind - different day and different search string found several sites listing the Delta 36-660 arbor nut assembly for left tile table saw. Just ordered one from Winner Woodworking -- no affiliation, but glad to find it.
For whatever reason, this part does not show up on Delta's own website.
Oh well! Glad to find it at last!
