OT Dvd discs
tom norton
>Are there different "kinds" of disc? A friend, from England sent me a disc and I get a screen message Not NTSC.
So...........?
OT Dvd discs
tom norton
So...........?
Yep...
Mark Williamson
>I am not sure of all the different kinds though perhaps you will get more insight from the other member's.
Mark
Listen PAL
Dustmaker Mike
>Yup the disk from the UK is in a PAL format. We use NTSC here in the states. So it is not compatialbe with a normal DVD player. You may be able to get your computer to recongize it but you will need a program to translate it. I have not seen any of these programs so I can not recommand one. I do have access to PAL and NTSC equipment so I just use the one I need.
Quick Search on Google *LINK*
Dustmaker Mike
>landed me a lot of information
PAL to NTSC DVD
REGION-1, REGION-2, etc
>Yes, if you're talking about pre-recorded Hollywood movie-type DVDs they are coded in such a way as to prevent people in certain areas of the world from viewing them.
In an oversimplified nutshell, the world has been divided into different REGIONS.... REGION-1, REGION-2, REGION-3, REGION...... I think NA is REGION-1, Europe is REGION-2, etc. but don't quote me on that. A DVD that is release in REGION-1 will only play n a DVD player that is made for REGION-1. And so forth.
The idea behind it is that if one of the major movie studios releases a DVD in NA, they don't want you to mail it to your relative in England where the movie is still in the theaters and not due for DVD release for another few months.
Same is true of DDV players. You can't buy a DVD player in Europe and bring it here and expect to be able to play NA movies on it.
It's less of a compatibility issue as it is a control issue.
That is why when you have a DVD player on a computer, the first time you run it it asks you what region you are in. Once you set it, it will only play movies coded for that region. You are usually allowed to change your region 3 times within the lfietime of the DVD player. But you can't switch it back and forth each week.
Happy Woodworking!
USA gets the short stick
Chad Pearson
>It is fairly common in Europe to get a vcr that works for all coded regions. These are not easily available here in the states. My view is that once again the recording industry is trying to stick it to us.
I despise this because my children and wife also speak Norwegian. I would like to reinforce their language skills by buying disks from Norway. These disks can't be used in my normal TV DVD player. I get around it by using a computer where I have elected to be in the European region. The downside is I can't use U.S. disks in it. Its not like I have a choice to buy US disks dubbed in Norwegian...they aren't available.
Re: OT Dvd discs
Tom
>There are lots of 'hacks' for many dvd players to make them region free. What player are you using?
Re: OT Dvd discs
tom norton
>I have a Tosihba SD-1800
