Re: Kitchen oven for kiln??
JohnKJordan in East TN
>Phil,
I haven't tried a kitchen oven, but I have used a microwave oven to dry 4/4 pieces. Perhaps it would work on thicker wood.
Following advice I read elsewhere, I used the "slow and easy" approach. I heated the pieces until they began to feel warm, let them cool, then repeated. Just before each reheating, I weighed each piece and wrote the weight on the wood. When the weight quit changing significantly, I was done. After several hours the wood was dry and ready to turn.
For another perspective on microwave drying, here's a note I saved from Russ Fairfield:
Microwaves and Pen Blanks
By Russ Fairfield (11-05-2000)
I use a lot of wood pieces that are either pen blank size or 2-1/2" square by 1" thickness. All need to be dry for turning. Because they are usually burl, wild grain, knots, etc. there is a lot of cracking during the drying and I was losing as much as 90% of the green Madrone and Myrtle burl and spalted Holly.
I gave up on boiling the wood. Beside the mess and time to boil the wood (1-hour in an open pot and �-hour in a pressure cooker), all of the color was leaching out of the wood, and the drying losses were only slightly less than that of un-boiled wood.
I figured that I would need more heat and less water, so I tried the microwave oven. Running Madrone and Myrtle burl on high for a sufficient time to get the internal water boiling out of the wood, then reducing the power level to hold that heat level until the water stops bubbling out of the wood (about 5 minutes), then letting it cool down in the oven, and then putting it into a vented box with a light bulb to maintain an 85-90F temperature until dry. My losses dropped to about 10%, with no loss in color.
This is totally contrary to the slow and easy approach to Micriwave drying that we would use on a bowl. The wood gets hot quickly and the water starts to boil out of the wood before there is any evaporation from the surface. 6 blanks arranged in a radial pattern on the rotating plate is the perfect load for the Microwave oven.
Added Note:
(My vented box is the old dishwasher described in Russ�s Corner here on Wood Central.)
After the microwave zap, the wood has done most all of its deformation, so from there on all it will do is to dry. Being burl, there are still some small shrinkage voids, but nothing that can�t be repaired.
This success prompted me to do some trials with pieces up to 3x3x6 (weed pot stock), and it didn�t work as well. The problem with the larger pieces is that the home Microwave oven doesn�t have sufficient power to get the water on the inside to boiling temperature without the wood starting to dry on the outside, and this is the perfect condition for cracking.
