Looking for a home made finish recipe
Lee Beeden
>I'm looking for a home made wipe on oil finish thats a little more durable then your average "in the wood" oil finish.
I don't seem to have a lot of luck with brush on or spay finishes.
Something that will give a little protection from water and harden to a film of some sort. I'm using it for the front of my kitchen cabinet doors, it will be applied over a miniwax oil based stain.
I would very much appreciate any magic recipes.
Lee
Re: Looking for a home made finish recipe
you can find it........
Bill Tindall, E.TN
>You can find it in the Holy Grail right next to the fountain of youth. Kitchen cabinetry is assaulted by water and grease. Only the most durable finishes last for a few years, presuming the kitchen is used. Thinning urethane makes it brush easier and urethane will hold up in these conditions. Or, learn to spray and use one of the high performance kitchen cabinetry finishes.
Bill White
>Not playin' word games with ya, but get more than a "littlt" better than wipe on 'cause the kitchen cabs will need more protection. I'd use a shellac seal coat (dewaxed). gel stain, then a wipe on ploy with at LEAST two coats lightly sanded between coats. I hope that you will finish inside the cabs too. Just a clear coat to seal everything.
Bill
Howard Acheson
>Here is a way to apply a varnish or poly varnish finish that does not involve brushing. Like any film finish, you can apply as many coats as you want. Five wiped coats is about equal to 2 brushed on coats.
A friend of mine put it together years ago and it has worked well for many.
QUOTE
There are a number of suggested application regimens that are totally subjective. The number of coats in a given day, the % of cut on various coats, which coat to sand after, when to use the blade and a whole host of other practices are all minor differences between finishers. There are some things that I consider sacred when applying a wipe-on finish.
First, you can use any full strength oil based clear finish. Polyurethane varnish or non-poly varnish is fine.
If you are making your own wipe-on the mix is scientific - thin. I suggest 50/50 with mineral spirits because it is easier to type than any other ratio and easy to remember. Some finish formulators have jumped on the bandwagon and you can now get "wipe on" finish pre-mixed. If you use a pre-mixed, thinning is generally not necessary. But making your own is cheaper and you know what's in it.
The number of coats in a given day is not important. Important is to apply a wet coat with an applicator and merely get it on. Think of a 16 year old kid working as a busboy at Denny's you have sent over to wipe off a table. Sort of swirl the the material on like you would if you were applying a paste wax. Don't attempt straight strokes. The applicator should be wet but not soaked. The applicator can be a paper towel, half a T-shirt sleeve or that one sock left after a load of washing. Then leave it alone. The surface should not be glossy or wet looking. If you have missed a spot, ignore it - you will get it on the next coat. If you try and fix a missed spot you will leave a mark in the finish.
Timing for a second coat involves the pinkie test. Touch the surface with your pinkie. If nothing comes off you are ready for another coat. If was tacky 5 minutes ago but not now, apply your next coat just as you applied the previous coat. Remember, you are wet wiping not flooding. After applying the second coat, let it fully dry for 48 hours. Using 320 paper and a sanding block lightly sand the surface flat. Now, begin applying more coats. Do not sand between coats unless you have allowed more than 24 hours to elapse since the prior coat. The number of coats is not critical - there is no critical or right number to apply. For those who need a rule, four more coats on non-critical surfaces or six more coats on surfaces that will get abraded seems to work.
After your last coat has dried at least over night you will have boogers in the surface. You should not have marks in the surface because you ignored application flaws. You may have dust, lint and, if you live in Texas, bug legs. Use a utility knife blade at this point. Hold it between your thumb and forefinger, near the vertical, and gently scrape the surface. Gentle is the important word - no harder than you would scrape your face. If you start scraping aggressively you will leave small cut marks in the surface. After you have scraped to the baby butt stage gently abrade the surface with 320 dry paper or a gray ScotchBrite. Clean off the surface. Now, leave the area for two hours and change your clothes. Apply your last coat with a bit more care than the previous coats and walk away.
An anal person is going to have a tough time with this process. Missed spots have to be ignored. Wet wipe, don't flood. Scraping to babies butt smooth means scraping no harder than scraping a babies butt. Ignoring any of these will leave marks that are tough to get out. Getting these marks out requires some aggressive sanding to flatten out the surface and starting over.
Jim Kull
END QUOTE
Finally, It works better to use a gloss varnish for all coats except the last. The flatterers in semi-gloss and satin tend to rapidly fall out of suspension when the finish is highly thinned. If you want a non-gloss finish, use it only on the final coat or two and be sure to stir the material frequently or you will end up with cloudy streaks.
Bart Goldberg
Bart Goldberg
>While not home made - I would recommend using Waterlox Sealer/Finish.
It is a mix of Tung Oil and Phenolic resin and is easy to apply - wipe on/wipe off.
Once Waterlox is fully cured - it is completely waterproof and can even stand up to boiling water without being damaged. And unlike Poly, it retains that oil finish look (not plastic like poly) and it completely repairable if it get damaged.
Bart
Re: a home brew finish
Glenn Madsen, near San Francisco
>I like Waterlox, and use it a lot. But for the bathroom, over maple and cherry, I used a thinned McLoskey's spar varnish, wiped on. Put some in a squeeze bottle. thinned it by a third or so, and wiped it on with the old tshirt sleeve.
The part about 6 coats is true, but then, I had no problem doing a wiped coat in the early morning, and another at night, and leaving it be.
And the bottle of finish didn't gel as fast as the Waterlox does, either. I think, though, that the Waterlox has a harder finish, which is a benefit in some furniture applications. Not so much for cabinets in a kitchen or bath.
Either way, it beat the dickens out of spraying or brushing. If I can avoid those, I'm much better off.
But don't use regular poly inside doors or drawers
henthorn
>Use shellac or one of the water type polys inside a cabinet.
Lee Beeden
>Thanks for the tip.
What do I thin the spar varnish finish with?
I'm guessing that any spar varnish will work, as i haven't seen that brand up here in Canada?
Thanks
Lee
Steve Schoene
>Spsr varnish isn't really a very good choice for furniture. It is formulated to be flexible and to resist UV light. It's not especially (any ?) more water resistant compared to other varnishes, but it is softer.
>I used the spar varnish because I had it, in clear high gloss, and it worked nicely. A good interior varnish should easily do as well.
I thinned it with VMP Naptha, for faster drying, but mineral spirits or paint thinner, in a decent quality, should do fine.
McLoskey's was said to have been purchased by someone else recently, so I wouldn't get too hung up on that particular brand. I'd head on down to the professional painters' store in your area, and ask for a good solvent based high gloss varnish from a reputable maker. If you believe what's written in the better magazines and websites, there's only modest differences between the reputable brands.
Thanks for all the input!!!!!!!!!!1
Lee Beeden
