Thanks Rick L
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>I picked it up this morning for $100. I figured at that price, I couldn't get burned too badly.
I have already started going through it. There are a few broken parts, but mostly it was just that nobody knew how to tune it. Both right side guides had slipped, and the blade jumped the thrust bearings, and was behind it. Duh, I wonder why it won't cut right?
Do you know of a source for parts for this brand? The bottom guide unite, cast aluminum, was bolted on with a fragile flange with a long slot, which was broken, but I JB welded it down after a little grinding. It has cured, and looks to be aligned OK, so I think I can get by without buying a new part, but if it isn't right, I think I can remove it with a bit of heat, and get some Carter parts.
However part of the little trunion that makes a cradle for the tilt is broken and missing a little on the back, and I may need to replace that casting if I can find it. So far, I have not found a source for parts.
I really appreciate your contribution to these forums. You always impress me with your depth of knowledge, and always give good useful information.
