Glass for cabinet doors *LINK*
Dan Mitchell
>I'm planning to change the panels on 5-6 of our kitchen cabinet doors from raised oak panel to glass. We like the look of 1/2" reeded glass, as in number 39266 in the Rockler link below. Their price is $0.10/sq", which would be about $32 per door, a bit more than I had hoped to spend. I will check with local glass suppliers, but I'm wondering if anyone knows of a cheaper source of such glass, perhaps mail order/online.
Thanks
Dan
http://www.rockler.com/product.cfm?page=10829&TabSelect=Details#glass
Re: Glass for cabinet doors *LINK*
Rick Jackson,TN
>Dan, I have done a lot of stained glass work in the past so you may want to check out a supplier in your area. Another option is this web site http://www.delphiglass.com/ for Delphi Glass I checked "reeded glass" and came up with a hit on a 14 x 27 in piece for $9.95. I have ordered from them in the past, and there are many others on the 'net as well. Rick
Dan Mitchell
>Thanks Rick, that site looks terrific, very helpful info. $0.026/sq" sure beats $0.10/sq"! If nothing else, it confirms my suspicion that there's a real range of pricing available. I wouldn't mind trying to resize these 14" x 27" pieces to the ~ 12" x 26.25" which I need for these doors, though my experience trying to cut plain window glass has been mixed at best, and the reeding detail on this no doubt makes it even dicier. With these prices in mind, I'll see what local glass places are asking.
Dan
Bill Roland (Mt Juliet,TN)
>If you use a thin oil on you glass cutter it will produce a real nice cut. Start your cut and complete with one motion using a straight edge to guide your cut. Stain Glass artist use a cutter that has a oil reservoir built in.
Ray Binnicker
>Since you are going to be taking out the wood panels do you think it may be possible to rout out the door frames to fit the the size of the new glass rather than trying to cut the glass?
Just a thought
Ray Binnicker
Dan Mitchell
>Interesting, I never tried it with oil. I think also my skill at "snapping" once I've made the cut probably isn't the greatest.
Dan
Dan Mitchell
>That's not a bad idea. I think it would work for the height, but for the width 14" wouldn't leave much. Even so, just in the height part it would cut the cuts in half. Really a good idea!
Dan
Rick Jackson,TN
>Dan, a couple of tricks cutting the glass. Oil as previously mentioned, turn the glass over and cut the smooth side not the reeded side, and try to have the dimension fall out in the "valley" of the redd. One key point, DO NOT go back over your cut that's where most of us screw up. Take one pass with the cutter pinch each side of the cut between your thumb and index finger and snap it like you would a saltine cracker. For $9 bucks or whatever it was, I would practice vs paying the upcharge at the glass shop. Of course always have your gloves and "and these....safety glasses" Rick
waroland
>Your "snapping" will improve also, just hold the glass with the cut line between your hands about one inch on each side of the line or lay it on a straight surface and snap. Don't be bashful when you snap the glass.
Re: Slight hijack...
>A while back I bought an inexpensive tile saw for cutting tiles for the bathroom. It's currently sitting in a cabinet in my shop. I haven't had any need to cut any glass - would a tile saw work reasonably well?
John E
>Never tried it, but I suspect glass would be too brittle to cut with a tile saw, unless it was fairly thick. If you try it, I would use VERY light pressure and SLOW feed rate. Ny 2 cents.
John
Rick Jackson,TN
>Agree with John, pretty sure the blade used for tile is slightly different than glass. However, there are band saws that will cut glass primarily used for shapes that are difficult to cut. Cutting glass really isn't that hard to do, a little practice like anything else.
Dan Mitchell
>"One key point, DO NOT go back over your cut that's where most of us screw up."
Well put me squarely in the "most of us" camp. I always figured the deeper the score, the more likely the glass would snap at that point. I remember as a kid one really old hardware store where my dad would occasionally buy glass, they had this bench with a long straigh edge clamp they used to score & also hold the glass along the score for snapping purposes. Seems like something you could rig up easily with a length of oak or the like & some clamps.
Yeah, for the price, this glass sounds ideal, though I haven't checked out the shipping yet. As we all know, oftentimes "that's how they get ya".
Re: Slight hijack... *LINK*
Dan Mitchell
>I had a glass shop in my former city make up some replacement storm windows for the house I was selling. They also made stained glass. I went in back with the owner when he was cutting the windows (which another guy had screwed up the 1st time... ) & was checking out his tools. He had a small red bandsaw, about 2' tall, a bit like the one in the link. I've often thought about trying stained glass, looks enjoyable, and if the prices some of the pieces get is any indication, potentially profitable.
http://store.allstainedglass.com/grypc40diamb.html
Another online source
Joe Pack
>You didn't indicate where you live. Another source I used for years is Franklin Art Glass in Columbus, OH (the folks who made all those Wendy's lamps). They provide outstanding service anb a great selection of glass.
Wherever you buy your glass, just ask them to cut it to size. They will charge little or nothing to do it for you, and the cut will be perfect.
If you do cut it yourself, be aware that the heavier, patterned glass is much more difficult to snap out than regular glass. Even if you use a new cutter (recommended...if you buy from a stained glass shop, ask for the proper cutter for the hardness of glass you are cutting...there IS a difference. If in doubt, buy the smaller diameter wheel for harder glass), use oil or kerosene as a lube, press firmly, and score only one time. Be aware that in a patterned glass, the break may decide to follow the pattern, not the score line, especially if the score line is "wimpy." The break will follow the path of least resistance, so be aware of patterns that curve off slightly along the score line.
25 years of stained glass crafting, but can't/won't compete with China anymore.
Don't do it.
Joe Pack
>Trust me, Dan, if you are using a thicker, reeded glass, your chances of cutting a 3/4" strip off the original sheet without breaking something are very small. Snapping a 3/4" piece off is NOT the same as snapping off several inches. To do that small of a strip, particularly one that long, I would use a special set of glass pliers made for the purpose...and I would likely have to clean up the cut with other tools. 3/4" inch strips are dicey, even with years of experience with hand tools.
Like I posted below, pay the extra to have the glass shop cut it to exact size. The few dollars spent will be saved in broken glass, particularly with the small trims you have to make.
I learned my lessons the old-fashioned way...I paid dearly for them! :-(
Franklin Art Glass  *LINK*
Joe Pack
Franklin Art Glass - Columbus
Re: Another online source
Rick Jackson,TN
>When I lived in Cincinnati, I went to Franklin Art Glass quite often. I was doing restoration work and some new pieces on the side for a woman who owned a shop in Cincinnati. ( I think she is no lnger there) but Franklin was her main supplier. One thing I did learn working with her is the mark up for glass and supplies is beyond belief, but as Joe mentioned, if you are doing this to make a living you can no longer compete with China. I still dabble in it as a break from the woodworking but only pieces for us, or family.
But if you do...
Joe Pack------WebKitFormBoundary+ck8IvgEXURxWCEA
>If you do try to trim a 3/4" inch piece off, you may have better luck by "tapping and running" than by snapping off a small, long piece. (Short, 3" or under, thin pieces are no problem to snap off with your fingers. It is the long pieces where you cannot control the direction of pressure that present the problem.)
This is the method I used to make thin, long strips from some VERY expensive, swirly, patterned glass for a custom order a few years back.
To "tap and run," make you score line as you normally would, then, place the glass, scored side down, on a piece of corrugated cardboard, thin carpet, a rubber router grip mat, etc...something with a bit of give, but not too much. Using the ball end of your cutter or some other fairly light, round metal object, begin tapping directly over the score at one end of the glass. Tap slightly harder until you see a crack developing at the score line. As the crack "runs" down the score line, keep moving up the score as the crack develops, tapping and "running" the crack the full length of the glass.
Your final edge will not be as smooth as a snapped edge, but a quick touch with a file or other metal object will get rid of the little shards that will develop along the edge.
Dan Mitchell
>Thanks for the continued responses on this, I just paged down & noticed the more recent ones. Funny you should mention Franklin, I used to live in Columbus & recall driving past the place a time or 2, but never stopped in. We're in the Seattle area now.
Dan
