Have a question? Ask Woody!
Mortiser/ HF Cross Slide vice question
>Several people have mentioned using a Harbor Freight Cross Slide vice with their mortiser. I use an attachment on the Drill Press to mortise with and was wondering about the HF vices. I looked at them for about two minutes the other day. They seemed really "sloppy" to me. So, the question is, do they work well for you? Do you end up with nice neat mortises? They had about five, which one do you have?
Re: Mortiser/ HF Cross Slide vice question
>Good Afternoon Barry,
I bought my 5 inch cross slide vise from HF. (Just went out into the shop to look.) I am sure that a greater degree of non-slop is available at much greater cost. Mine was less than $50. It maintains its alignment during travel, completely satisfying my needs. My mortises are clean/well cut. No problems.
George
Rob Stokes in North Vancouver
>Barry - don't buy the x-slide vise and expect a finished product. You need to take it apart, clean up the machining and casting (with a file) and re-adjust the tolerances. I also re-drilled mine so I could swap the vice-clamp handle end-for-end. This means the front/back adjusting handle and the vice clamp handle are on the same side of the vice. They interfere with each other, but it's not a big deal.
With some fiddling, filing, flattening and adjusting along with dome dry-lube, these cheap vices can be made to perform very well. I use mine on my morticer and there's no going back.
Rob
Ken Platt (Granby, CT)
>Mine says Pittsburgh #S32996 5" cross slide vise. It's been awhile, but I thought it was from HF. I have used it for maybe 5 or so years to make mortises, with the drill press, but I used a solid carbide spiral bit in the DP (no mortising attachment). It always worked well. There are some allen screws and thumb screws that can be used to snug up the ways, IIRC, and it always tracked just fine.I have a dedicated mortiser with it's own XY slide vise now, but I'm not sure it's really much better.
I've used the XY to drill pen blanks, too. Makes it easier to maneuver the blank around to get the drill centered.
I think Grizzly has them also fairly cheap.
Ken
Yes, and Amen
