>I was under the crawl space checking the 220 line that I installed to the shop noticed that the Dryer vent exhausts into that space. Should I drill a hole in the wall and exhaust it outside or is it fine like it is. I didn't notice it before I had the crawl space insulated because it had a dirt floor. Now it has the plastic down.
>John, this is definitely not good, for several reasons.
The last think you want to be pumping into your crawl space is warm wet air. Encourages mold (rot) and insects.
Also, there is the possibility of a dryer fire. Some of the lint these days comes from fabrics that have very low ignition temps and it it possible for it to catch on fire and set your house ablaze.
Then there is the possibility that some of the fumes might not be good for you.
The dryer should be vented outside through metal venting, not the old plastic slinky hose. (They burn through easily and restricted air flow.) Better to use hard pipe (4" metal ducting). Turn the snap seam up and fit the male end into the female end so that they funnel the air out. (The seam goes up to resist water drooling out in the event of condensation.) Foil tape the connections. (No screws sticking through to the inside to snag the lint) If possible, slope the pipe down toward the outside to allow condensation to run out.
You can use the metal flex pipe, but it is not as tough and it tends to restrict the air slow.
As a Home Inspector I have seen many houses damaged by unvented dryers. Don't take the chance.
>One other thought is to make the vent line extension slope down to allow any collected moisture to drain. I had one in my apartment that was really long and it drained back towards the dryer. Now and then, I had to drain the water out of the dryer duct between the dryer and the wall. That got ugly!
I've been looking at buying one of those cleaning kits and cleaning ours out. We are real good about cleaning the vent and I lean the dryer out once every few months, but I wonder what the vent looks like. Ours is a straight vertical run right up the wall to the roof.
>For all of the reasons above plus, yes Virginia, mice CAN crawl up that spout ! You ain't smelled nuth'n till you have a mouse roasting in your dryer ! And it NEVER goes away. EVER !
>What they said, and I would add, change the whole line out to rigid 3" or 4" duct ( NO PLASTIC !!), that will let the lint go through easier. Put it on your calendar to check it once or twice a year. Also, if you do use the rigid duct, tape only, no screws. Screws just give the lint something to grab on to.
Some of my fire buddies tell me that lint/dryer fires are the #1 cause of house fires................
>Tony, its a good idea to at least check that vent. Vertical vents are frowned upon by the dryer industry. The problem is the "snow ball" effect. The dryer tries to blow lint up and out, but some of it falls back down. Each load adds a little lint to the ball and eventually it stops up the pipe. Dryer fires can be serious, as serious as burying your house down.
I cleaned mine and it cut the "dry" time almost in half. The vent was partially blocked, reducing the amount of air, increasing the time to dry. It really made a difference.
Several people have posted about buying dryer vent cleaning brushes. They were pleased. Maybe they will jump in. I did not record the Site where they found them, Sorry.
You can improve your vertical vent by adding a Tee at the bottom, creating a "drip leg". Put the dryer in through the horizontal leg of the Tee and let the air turn upward. The vertical leg of the Tee serves as a reservoir. You cap the bottom and a couple of times a year, remove the cap and clean out the crap.
>Thanks for the info barry. I bought the kit at Lowes on the way home Friday. Fortunately, mine was very clean after 9 years of use. Comforting to know it is nice and safe though. Weird thing is, I found a baby bird skeleton. I mean little tiny no feathers kind of baby. No nest debris or anything like that. The outlet on the roof is such that there is no way to have a nest on it or in it. I wondered if the baby got there during contruction somehow. I noticed the condensation pattern on the roof yesterday when my wife was drying some clothes. It was pretty obvious that there was plenty of hot air coming out.
