Bench top mortising machine users ?
Pete in Holland, MI
>Looking at buying a bench top mortiser. Am debating between the JET, Delta, Shop Fox and Steel City. Any disappointed users out there ?
Also - - has anyone heard if/when Woodcraft is having one of their 10% off sales again ?
Thanx !
Pete
Re: Bench top mortising machine users ?
Denis Ch�nard, Orl�ans, Ont.
>I have the Steel City, no experience whatsoever on the other brands.
Overall, I like it quite a bit. Two negatives: the chisels and bits (included) were not sharp at all, I had to find a way to sharpen them (I did). Second, the hold-down has a tendency to bind the piece, and needs a hex driver (included) to set it up. I would prefer tool-less adjustment.
I haven't used the machine much, but it's good overall. I would buy it again, despite the above criticism.
DC
Larry Clinton At Frankfort (Central)., Indiana
>I have the Fisch 3/4 Hp unit with the 1724 RPM motor. I have never used the other brands. The Fisch came with three Guildcraft chisels / bits. I have been very happy with the unit. You might want to include it in your research / choices.
>Hi, Pete,
See my review of the JET in the Reviews section. I still have mine, and still use it. Would I like a nice P-Matic floor unit and/or a set of Clico chisel/bit sets? Absolutely, but I don't have the space for one nor the justification for the price of the other? Note that you can improve the functionality of these units with the addition of a cross-slide vise like Harbor Freight sells.
Re: Bench top Review  *LINK*
JET-JBM-5
Jesse Cloud
>I have the Powermatic benchtop model. For a benchtop mortiser, its very good - easily adjustable, great fence, good holddowns. I use the Lee Valley chisels and keep them razor sharp.
However, I find I use this machine less and less. There's just no way you will get as clean a mortise as you will with a router. I spend a good deal of time cleaning up the mortises with chisels.
On the other hand, compared to a router, its very quiet and safe.
Verne in NJ
>I have an older version of the Delta mortiser. I don't use it that often, but when I do I'm glad I have it.
One thing to consider - a 1/2" bit in tough wood taxes these machines. I'm building a workbench out of ash and I made some wide and deep mortises in the legs, and the machine constantly jammed up using the 1/2" bit. I was using the high quality Lee Valley chisel, but the motor just didn't have the umph.
So depending on the work you're doing and the wood you're using the benchtop machine will probably fill the bill. If I ever replace it, my dream would be to buy a mortising attachment for one of the combo jointer/planer machines.
>Good Morning Pete,
I have had my Shop Fox #W1671 for several years. Its a dual post 3/4hp design which has a rotatable base, permitting mortising off the table side into wood ends if necessary. It has more capacity than the smaller bench tops on the market. The Shop Fox chisels I bought with the machine are fine. I incorporated a cross slide vise from HF or Grizzly. It does away with the standard fence and hold down apparatus, and makes mortising a breeze and fun besides. This is a larger, more capable machine than most bench top models, and is priced only slightly higher than the 1/2hp counterparts. I'd buy it again.
George
