A55 Smoothing Plane
How to Stack and Sticker Red Oak
Howard
>I'm having 1,000+bf of red oak milled on site and need to know what I should use for stickers and is 3/4" spacing between each layer enough. Also, should the boards have space edge to edge? Thanks for the tips, first time doing this but I think it will be real cool using my own lumber in my work.
Re: How to Stack and Sticker Red Oak
>You can go over to Woodnet.com and learn more about this than you ever wanted to know.
3/4 stickers may be OK, if you have good air circulation. 1" might be better. I used ones I made myself and the were just under 3/4" I used a thin kerf blade and ripped about a mile of lumber I got from Lowes in their junk pile. Mostly spruce and pine. By using a thin kerf blade, I got .7" square pieces out of "two by" stuff.
I stacked about 5000 feet of walnut in a open shed on a barn on a windy hill. Excellent air flow and walnut is easier to dry than oak.
You want the bottom of the stack to be six or eight inches off the ground (Keeps it dry and good air flow again) and very "flat" and level. The stack needs to lie in a "plane" and be very flat. If it is not you might imprint a twist or other warp into every piece. You cannot keep every piece from warping, blunt you can warp every piece.
The stacks should be neat with the stickers directly above each other and 12 or 16" apart. IF you stagger the stickers, they tend to cause the boards to ripple or warp. There should be air space between the boards and if practical the cracks should line up with each other to allow vertical air flow as well. The stack should be 3 or 4 feet wide. There should be a sticker right at each end of each piece.
Waxing the ends is a good idea and may save a small percentage from cracking or checking.
Not wise to use green lumber for stickers. Oak is subject to sticker stain.
Stack your crumby lumber on top to serve as weight on the good stuff. Cover the pile well to keep the rain out, but leave the sides open for air flow. More weight on top is better than less.
Some people rearrange the stacks periodically, but I was too lazy. Putting the crappy stuff on top may discourage thieves and those of us that would start working on the wood too soon.
check articles
Bill Tindall, E.TN
>in the Articles there is a series on Where hardwood Comes From. Check the section on drying wood.
JohnKJordan in East TN
>I use 1" rough sawn wood for stickers, but the consensus on the Wood Web is that 3/4" is often sufficient. You might the Knowledgebase there for stickering details.
Be careful with stickers or you can stain the boards and/or introduce a lot of unnecessary warpage. The author William Brown (mentioned below) recommends 1" except for wood prone to split such as oak. For valuable oak, he prefers sticks 1/2" or 5/8" thick to slow the drying if the first fiew months of drying coincide with warm weather. (it is important not to dry oak too fast.)
Dry hardwood is recommended for stickers. Wet stickers can encourage fungus. You can buy ready-made stickers made of hardwood or other materials. Some good advice I've read is don't skimp on the stickers - the success of your entire lumber stock rests on your stickers (pun intended).
Most people stack the lumber with the board edges pretty close but if boards are in tight edge contact you risk sap stain or fungus. Boards are usually piled close to encourage air flow evenly over the surface instead of "leaking" up through the stack for uneven drying. Some recommend leaving a "chimney" up the middle in some circumstances. One of my books recommends this for "poor drying conditions or where the stack is wider [than 6'].
If you haven't already started on your stacks, be sure the bottom of the stack is about a foot off the ground. What I do is put two rows of cinder blocks flat on the ground, the rows about 30-36" or so apart. (I make relatively narrow piles, about 4' wide.) Level the blocks with a shovel and/or wedges. (warped foundation can result in warped boards.) Set two long beams (usually as long as your lumber) down each row of blocks. These beams should be 4x4 or 4x6 for heavy stacks. (I generally saw some junk pine for beams since I have plenty.) Lay a row of shorter 4' beams across the longer beams spaced about every 2' For the first row of stickers lay one stick directly on top of each 4' beams. There's a good article by Paul Berturolli in the Taunton FWW publication "on Wood and How to Dry It" that describes this method and has pictures.
There are lots of good resources on the web on how to air dry wood with minimial degrade. I like this book: The "Conversion and Seasoning of Wood" by William H. Brown. If you haven't air dried wood before, you might research this carefully to avoid ruining a lot of lumber.
Some good info:
http://www.woodweb.com/KnowledgeBase/KBIndex.html
http://www.woodweb.com (drying forum)
http://www.forestryforum.com (Sawing and Drying forum)
I did it
Stephen Kirk in Quakertown, PA
>I have some that is now dry. I stickered using 1x3 boards that I'd rip down the middle to get roughly 3/4 by 1 or so. Cut them to the width of your stack and go to town. Stickers every 12" or so worked OK. Make sure your base is level. Leave a little room between the rows and room around all edges. Weight it good, cover it and forget about it. I checked every couple of weeks or so to look for obvious problems - like the covering leaking, major insect damage, serious cracking/warping, etc. I really didn't do anything and I'd say about 80% of my stack came out well. The was my first time trying to dry.
If you are starting in cold weather, it's even easier. You don't have to worry about stickering within 24 hours to prevent mold formation.
Other than that, just start making plans to use the lumber. I did 650 bd ft, and it's a lot of wood.
Thanks All-I've got 1 more question in new post
Howard
