OT Outlook Express Question
>I have Comcast Internet and use Outlook Express to handle the mail
I am in a group that sends out group E-mails. Outlook has the annoying habit of Stopping when it gets to an invalid address and doing nothing. When I hit "reply to all" it scans the addresses and stops at the first bad one and does nothing, except to report it hit a bad address. I take that one out and it goes to the second bad one and stops again. Then the third and so on.
Since various people in the group have various lists, this is really annoying.
Does anyone know if it is possible to go into Outlook Express and tell it to send to all the good ones and ignore the rest or to report all the bad ones at one time? I would be happy if it would send all the good ones and screw the rest, as I don't know how to correct them anyway. Half of them have goofy cutesy addresses and I have no idea who they are.
And does anyone know how to set up a "Group" in Outlook Express?
Re: OT Outlook Express Question
Bill Howatt
>Type Group into the OE Help and it will tell you how to set up a group.
No idea about the bad address problem but OTOH I would sooner it quit at a dud address than let me think that the message went as intended. Hopefully, somebody will have a better solution for you.
Bill
>Its interesting how people see things. You would rather have it stop at a dud?
I see it the other way. I can't send anything to the duds, because they are duds. And since they used those indecipherable addresses, I don't know how to ask for a better address. So, I would rather that it sent them to the good ones and reported that it found the duds.
Sort of like if I told my employee to do ten things and their response was, "When I realized I couldn't do No.3, I just quit and did not do anything." "And by the way, I did not check to see if there were any other things on the list I couldn't do either."
I'm thinking I will learn to set up a Group and then I will send to those people. That raises and interesting point though. Many people change their e-mail address and then it will fall to me to keep the list current. OH, well!
Bill Howatt
>I understand your frustration at it stopping but the last thing I would want was to think I had successfully sent a message telling everyone to be at an important meeting and several people didn't get it. However, I a better solution would be to send it to the valid ones and tell you about the invalid ones.
What I'm not clear about is how OE knows they are a dud in your situation. If they are available in the form abcd@xyzqr.abc it will send it out (I just sent out that address)but it should bounce back as undeliverable. I think your problem is a syntax problem on your TO line. There should be ; between each person in the TO list and if there is something there like "Fred Jones" then it must have a link to the abcd@xyz.mno form of the address.
Bill
>Bill, this just gets weirder and weirder.
I took out three address that were flagged as wrong before the message even went. One of them was addressed to NAME@yahoo.coom. The other two were Comcast.net addresses and I use Comcast. Apparently, it went to it's own data base and checked them before trying to send the message. (I talked to a Comcast rep and they were no longer valid address. We even tried several different spellings, no luck)
In about half and hour a "failure" notice came back on another one. At that moment, I was sending an e-mail tot he original sender, suggesting he clean up his group list, explaining what happened. Now for the weird part.
Once I took all the objectionable ones out and sent the Return to All, I then sent the one to the original sinner telling him of the problems with his list. A few minutes ago, I looked at my e-mail and both f those came back. Apparently, Comcast does not recognize the address he used two hours ago.
Chuck W
>Barry,
A suggestion...
The Microsoft help forum for OE is a good place to post questions.
