Burning Exotic Wood in Fireplace?
Mark Kauder, Phenix City, AL
>I am sensitive to dust from many exotic woods.
Does anyone know if burning exotic wood in a well vented fireplace poses any hazard? I know it burns well. I am cleaning out scraps from my shop that are too small to use for anything (even slimline turned pens).
Thanks,
Mark
Re: Burning Exotic Wood in Fireplace?
If the fireplace is working correct
Dustmaker Mike
>all the smoke goes up the chimmy and there should be no hazard of it coming into the space. I have burned a lot of stuff in my fireplaces over the years with no ill effects.
If you can handle the wood in whole form and you just get a reaction from the dust then you should be fine.
Mark Williamson
>I turn miniautres! What kinds of woods are you getting ready to burn? I sometimes use pieces as small as 1/8 thick by 1/2 sq.! I use the smaller pieces for collars and bases for very small mini's. From one regular pen blank I get three to four vases or hollow forms alone! Not to mention a good ebony, cocobolo, any other very dense exotic pen blank can yeild 6 - 8 finial lids. You may not get a pen from it but that doesn't mean you can't get something from it!
Have you already burned them? :(
Mark
>As Mike said - not if you have a well ventilated fireplace.
The only thing that you may be leery of is burning "oily" woods. The ash of some of the exotics can also be nasty, what with the silicates.
>Thanks all.
Mark
>Mark,
Look for a private email from me.
Mark
Mark Williamson
>Just an idea of how small I get with the turnings sometimes...
Turned and completely hollowed from ebony that could have easily been sacrificed to the woodstove gods! ammmmmmmmm
Pictured with a grain of rice
Wow, with my luck...
>...I'd sneeze, or maybe inhale that little thing. Nice work.
Guilt
WRF
>wOW. I feel so guilty.
Scraps from my cutoff box (walnut cherry and maple usually) regularly make the trek upstairs to burn in the fireplace. Dont ever keep anything smaller than you could use for a good sizes bandsaw box.
Consider those down wind of you too.
Bill Hammond, Oregon Coast
>While the smoke may well go up the chimney and not bother you, someone downwind may also be allergic and will have no idea what is happening. Rarely does smoke go straight up and off to the moon. Often it engulfs the house next door, or if your unlucky, your house and is sucked back in as air goes up the chimney. If I were burning something hazardous to me I would make sure that the air feeding the fireplace does not come from the house in general but from a dedicated outside vent directed to the fireplace. I would also make sure it is not affecting someone else.
Last house I lived in the neighbor burned garbage in a living room fireplace insert. The stench in my house got so bad that we called the fire department, the fireman never got out his air quality measuring device, he took one whiff and marched next door and read them the riot act. That stopped the garbage but then they started to burn treated lumber end cuts... Another call, another visit. They soon moved because the neighbors were so unfriendly.
So that's my story, please consider the guy next door.
Bill
Re: Wow, with my luck...
Mark Williamson
>Thanks! I have dropped a few pieces that size right after separating them from the lathe never to find them again! I know they are down there somewhere, but they bounce quite well! LOL
Mark
Re: Guilt
Mark Williamson
>They can't be generating THAT much heat? I think you should not even bother with that old woodstove and send them to me instead! Let the guilt build within you! Hear the screams of those poor little pieces of wood....
"Send us to Mark in Virginia! PLEASE don't burn us!" Listen to them close, I swear you will here them! hehe
Mark
Re: Consider those down wind of you too.
VLParisian
>Try burning some Huisache (Sweet Acacia) in the fireplace. Smells like burning dirty diapers. That should keep the neighbors indoors.
Victor - in cold and damp houston
VLParisian
>I know you are just burning scraps, but some of the exotics have a very high BTU content and burn too hot for most conventional fireplaces. Mesquite comes to mind...DAMHIKT.
Victor
Don Orr
>Interesting topic Mark, with some VERY interesting responses. I give a lot of my chips to my wife's pottery guild for Raku firing. I am very careful to NOT include exotics when I bag them because I don't want anyone to have a problem. When we put glowing hot vessels into the chips, they ignite and we put more chips on top and then cover the trash cans to let them cool and reduce. The smoke can be pretty bad when we open the cans to take out the pots. I even try to keep walnut out of the mix. If I turn exotic wood, I try to clean up before and after or just dump the whole mess down back on the wood waste pile to break down on its own. Don't want to cause any trouble with peoples health. I give you credit for being concerned as well.
