Hair wrapped around casters
Tom Dunlap
>Today my brother snagged an office chair for me before it went to the dumpster. The chair is in good enough shape for my behind.
When I got it home I tried to move it around and I found that the casters were sticky. When I flipped the chair and pulled a caster I found that hair is wrapped around the axles. After pulling and poking at the hair, it doesn't look like any carpet that I've seen, I'm wondering if the person had a dog that would cuddle under a desk and loose some hair every time the chair swivled. Youch!
What can be used to dissolve the hair? I thought about using Drano but I remember trying that on a P-trap and still had to dismantle the trap and found a mondo hair ball still in place.
Thanks for any ideas.
Re: Hair wrapped around casters
Ken Platt (Granby, CT)
>I don't know about dissoving the hair, but in my business we not uncommonly have to remove things which are too tight around appendages. A couple liberal applications of mineral oil frequently make things slide apart amazingly well.
If you are curious, there really is a medical entity called a hair-thread tourniquet; I've had to remove my share. Usually from things less cooperative than a caster.
Ken
Jason Roehl in Lafayette, IN
Might stink a little, but..
>...I would think that a little careful waving of a cigarette lighter or propane torch on the hair should burn it away. Hair burns pretty easily, as my various grill-lighting experiences have taught me.
Jason
JohnKJordan in East TN
>I've used a sharp blade (xacto) and/or some small (surgical) scissors.
Two-staged solution
Tom Dunlap
>The first thing I tried yesterday was to use box knife blades to slice the hair. Then used forceps to dig out the stubble. This didn't work too well.
Today I'm going to burn off what I can with my long stem grill lighter. After that I'm going to slather on some depilatory cream and see what happens.
This is what I found:
Depilatory Creams and Lotions contain chemicals that easily dissolve the protein that makes up unwanted hairs. Depilatories are chemicals which dissolve hair at the skin's surface. It works by breaking disulfide bonds linking the protein chains that give hair its strength, making the hair disintegrate.
Bill Schreiber, Litchfield, NH
>Growing up on the farm, we would always have PTOs that would get wrapped with hay. What we would do is take a knife and cut all the way through every strand in one place. Then, all you have to pull out is hair that is the diameter of the caster's post.
Just an idea before trying all of the chemicals.
Regards,
Bill
That was my first thought
Jay in Tx
>But make sure to be outside... no kind of burnt hair I've smelled has a good aroma.
Solution
Tom Dunlap
>Thanks for the ideas.
Yesterday I pulled the casters off of both chairs and headed to the shop. After clamping the caster in the vice I used a couple of blades to saw down to the axle. then I took a piece of cord with overhand knots tied about 1.5" apart and wrapped it around the axle. The cord became a 'floss' and the knots snagged out the hair gobs. This worked pretty well.
Some of the casters are still a bit stiff so I think that the axle races are gummed up. A bit of lube willhave to do.
I used a lighter to burn off some of the fuzz too...stinky!
Tom
