Hinge Choice
Hinge Choice
Hinge Choice
Howard
>I am re-wording my earlier post - I have frameless cabinets made of 3/4" ply that have drawers inside. They slide on KV8400 slides. The space from the drawer side to the cabinet side in 1/2" which is not enough room to fit a Blum clip 3 way adjustable cup hinge. Doors are 3/4" thick full overlay. I did not plan ahead enough, now I need to rethink this. Is there another hinge of this type that would fit, or do I need to go with butt/wrap around hinges? Appreciate your help.
Re: Hinge Choice
Re: Hinge Choice
Thomas S Stockton
>Howard
Look into a blum "compact" hinge. compact is there trade name, they use a different style base and cup hinge
Tom
Re: Hinge Choice
Re: Hinge Choice
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>Howard, If I understand your question, you are putting drawers behind doors. I have dealt with this since the fad started back in the early nineties when it first showed up in the magazines. Let me say up front, that I think this is a dumb idea. You need to fur-out the side of the cabinet about 3/4" to get the hinge out of the way of the drawer / pullout shelf.
What it was supposed to do was make it easier to get to the stuff on the back of the shelves, but it actually waste space in the cabinet. A four drawer stack with regular drawer fronts makes a lot more sense, in that there is less wasted space. Plus there is just the motion of opening a drawer to get what you need, then close the drawer.
When you have a pair of doors in front of drawers, then you have thrown in two extra steps to get to the needed object then the same extra steps to close the door or doors, after closing the drawer. I just won't do it. I argue very vigorously against it and point out how much easier it is to just have drawers.
My advice is to just cut your door up into drawer fronts, then put them on the fronts of the drawer boxes. It will save the customer lots of work forever after when they want something out of the drawer.
Re: Hinge Choice
Re: Hinge Choice
Dave Bair, Eaton Rapids, MI
>Couple of notes here:
The customer probably wants doors, not drawers, on the cabinet fronts. They look traditional and asthetics may be more important than utility. I know, my wife just could not get on board with big ole drawers, even though the pull-out shelves (drawers) are less convenient.
Knife hinges may work for your application. They are basically invisible and move the door out of the path of the drawers. There are some pricey ones out there though.
Re: Hinge Choice
Re: Hinge Choice
Howard
>Thanks for the great suggestions, I think I've come to a solution and will report back.
