Help Help
Help Help
Help Help
Howard
>I screewed up-just built framless cabinets with drawers on KV8400 slides. Doors are full overlay, case is 3/4" ply. Plan was to use adjustable Blum cup hinges, but I did not leave enough room for the protrusion of the mounting plate(I know, stupid!!). The finish will be a medium brown tone, so if I use some type of barrel hinge, I'll need it in a color to blend with the finish. Can I please have your suggestions - if I need to use butts I don't want the barrel too large. I could also cut down the drawers to make room, but prefer not doing that. Thanks.
Re: Help Help
Re: Help Help
Dick Coers
>Could you explain your problem a little more? Where is there not enough clearance? Blum makes so many hinges, that will just about work anywhere. Do you have hinges that are made for full overlay, or did you get some for 1/2 overlay by mistake? Maybe I can help with a little more info.
Re: Help Help
Re: Help Help
Howard
>Thanks-the problem is I can't use the 3 way adjustable hinge on a framless cabinet that has drawers with slides mounted to the sides of the cabinet. Once the hinge is clipped to the mounting plate, there is only 1/2" clearance between the drawer side and the side of the cabinet, not enough to accomodate the hinge.
Re: Help Help
Dick-
Howard
>I am referring to the space between the drawer side and the side of the cabinet which is only 1/2 inch, the thickness of the kv8400 slides. I can't get the hinge in that tight space if I wanted to use the Blum 3 way adjustable hinges.
Re: Help Help
Re: Help Help
Dick Coers
>I understand the problem now. My first thought is to cut an 1" or so off two of the drawers so they would clear the hinge. If you wanted to, you could just trim the one side. Another hinge option would be the instituional hinges. They have vertical and horizontal slots that allow some adjustment and get the door out of the way for the drawers to pull out. They will have the barrel outside the door though.
http://www.rockler.com/ecom7/product_details.cfm?offerings_id=10052
A desperate act, to use the european hinges, would be to mortise the base plate and hinge arm into the side of the cabinet. You would use half overlay hinges for that, but you would also run short of cabinet wall thickness for the mounting screws.
I think you've kinda painted yourself into the corner on this one. Good luck.
