Question on Lion Batteries.?
>I have a Hitachi battery powered screw driver that has Lion Batteries. The screw driver rides in a tool box in my car and I use it in my work as a home inspector. This morning it was very cold for us, about 12 or 14 degrees. I went to use my screwdriver and it was dead as could be. Nothing. Not even a hint of a charge. (It should have been nearly fully charged). I stopped by my office and picked up the alternate battery and it is fine. My question is, is it unacceptable to freeze Lion battery?
As an aside, I have been carrying rechargeable flashlights and screwdrivers with nicads in them in my car for years. Also regular batteries. No apparent harm.
Re: Question on Lion Batteries.?
Looks like you don't want to freeze them *LINK*
Dustmaker Mike
>Towards the bottom.
Care
Tony - Memphis
>Yeah, that's an issue with Li batteries. We have well over a hundred thousand Li batteries in service here. Since we changed, we have had to be much more concerned with temperature of the batteries in charging and in service. A lot of our chargers were in unconditioned spaces before. They can get too hot to charge. Battery life has been an issue too. Tough call - with todays devices running Windows Mobile with all the bells and whistles and three radios inside, we need a lot of power, but don't want the weight. So, Li is the answer with some compromises of course. I've always questioned Li for contractor applications, but I guess it is working ok. My concern was the heat. Heat kills 'em.
Tony
Re: Hmmm Barry, my GPS has the Lion
Larry Clinton At Frankfort (Central)., Indiana
>battery (Magellan Maestro 4000). I leave the Gps in the car - outside. (Don't want to clutter up my shop :~)). I haven't had any problems with it yet, However I do have it hooked up to the car power. I guess I haven't had it taken off the automobile power long enough to tell if the battery is ok. If freezing does hurt these, I would suspect most GPS units will have a problem. I (and I am sure most people) leave them in the car when it is parked at the destination. Here in Indiana it has been at 0 deg.F often this year. Wouldn't take long for the unit to get below freezing - Hope it isn't an issue as the battery in my unit is not replaceable except by a service center (according to the literature).
Leaving it on the charger helps
Dustmaker Mike
>cause as the battery drains or reacts to the cold the charger keeps it up if the charger is working there is a little heat produced so they may never freeze in the GPS. That is my SWAG and I am sticking to it until sombody smarty then me tells me different which is just about anybody on this fourm.
Re: Leaving it on the charger helps
JohnKJordan in East TN
>... but don't forget to read the instructions! My latest LIon battery and charger (for a camera) came with explicit warnings to not leave the battery connected to the charger. I suspect some chargers may do less to prevent overcharge.
