size of Mast-R-lift
size of Mast-R-lift
size of Mast-R-lift
Jim from Fenton, Michigan
>I'm building a new router table and I want to make sure the compartment for the router is deep enough for a Mast-R-lift. Problem is, I can't find the dimensions anywhere. I've checked the JessEM site for manuals but they don't have the dimensions nor do any retail sites that sell them. Does anyone have one that could measure the length of the carriage rods so I know how deep to make my router compartment? Thanks in advance.
Re: size of Mast-R-lift
Tradd
>I just measured mine and it is 10 3/4" from the top of the plate to the bottom of the rods. Hope this helps.
Jim in Fenton, Michigan
>That's exactly what I needed.
Thanks...
sawdustdan
>I have a PC7518 mounted in mine and the motor head extends 3-4" bellow the rods when fully lowered so you need to account for that plus the rod length
Dan
>Thanks for that. I'll be mounting a PC7518 as well. I have 14 1/4 inches of room from the underside of the table to the bottom of the router compartment opening. Maybe I should give myself a little more room.
