Re: quarter oak warping- help!
Rob Stokes in North Vancouver
>Were the pieces laid flat on another surface for a few days? Did they all cup the same way (up or down)?
Reaction wood usually shows itself the instant if comes off a saw blade so if it was internal stresses in the wood causing the problem you'd have been cursing the wood long before now.
Which leads me to thing that it's unequal moisture levels in the wood when comparing the "up" side of the stick (the horizontal face open to the air) with the "down" side (the face that was on the table/bench).
The "up" side either shed or gained moisture freely as it was open to the atmosphere. The "down" side would have been inhibited from doing the same thing as it was in contact with a surface. As the moisture in the "up face" changed, that face expanded (if the moisture level in the wood increased) or contracted (if the moisture level in the wood decreased) accordingly. Thus the warping you notice.
It's (typically) easier to add moisture than it is to remove it and there's several ways of doing this. If it was spring, I'd suggest you put the pieces on the lawn with the "dry" side face down. Instead, you may want to simply flip the pieces over and see what happens after a few days, or place them face down on the bathroom counter next time you have a shower - and leave them in there a while, or you can even try moistening the wood with a damp sponge. If the pieces are severely cupped and won't actually contact the surface you lay them on, try covering the "wet" surface with masking tape to prevent over saturating it as you attempt the black magic tricks.
Whatever your chosen method, you need to equalize the moisture content in each of the four sides. And while the methods I describe are usually successful when dealing with a plank, dealing with a stick is a bit harder as "straight" is typically a more accurate measure with a stick. But it's worth a try.
Next time you make sticks, or want to leave wood for a while after milling it, sticker it properly and you shouldn't have this problem repeat itself.
Good luck!
Rob
