OT-Laptop file synch software
Brian in Brighton
>For those fellow compgeeks who need to synch large amounts of data between your desktop and laptop, what software do you use?
There seems to be a lot of options to determine what to do this with. I need to synch 24,000+ cad files between the 2, so simple freeware usually will not do as it's limited in file qty.
Brian in Brighton
Re: OT-Laptop file synch software
Re: OT-Laptop file synch software *LINK*
Tim Caley - North Litttle Rock
>I use FileSync. Works very well. It is shareware, but I have found no limitation on the number of files that it will do.
http://www.fileware.com
Re: OT-Got it figured
Brian in Brighton
>A while ago I asked a similar question about using backup software that doesn't make a vault. Someone recommended Syncback and it can also do what I want now.
Thanks for the input.
Brian in Brighton
"I cut it three times and it's still too short"
