Is My Ridgid Sander DOA?
>Have had a Ridgid oscilating belt/spindle sander for about 7 years; has seen much use and has done well. Changed out the belt unit for a spindle last night, and hit the switch. It went to the top of its stroke but stayed there spinning with much noise like a gear has given way.
Questions:
1. Anyone here have one of these that did this, and how/did you fix it?
2. If you had it repaired, what did it cost?
The nearest "Ridgid" repair shop is 30 miles away, and I have to wonder if 2 trips plus the repair cost is gonna be worthwhile on a $200 tool.
TIA
mm
Re: Is My Ridgid Sander DOA?
Last Rights
>Have been administered by Ridgid Technical Support.
"I'm sorry, sir, but your oscilation cam has broken. The only way to fix that is to replace the entire motor unit."
"Ah . . ., how much is a motor unit?"
"Checking my parts list . . . . shows 'No longer available' so I'm afraid I can't get you one, sir. A repair center might have a spare on a shelf, but the unit is 7 years old, so I would not be hopeful of that."
[dirge volume up, exit stage left]
Re: Last Rights
Rob Stokes in North Vancouver
>Interesting - this is the first I've heard of one breaking.
I know when I bought mine, which was about the same time you got yours, HD still had a lifetime warranty. Curious why they're not fixing it/replacing it under that warranty?
Rob
Disinterred!!
>Thanks Rob, I completely forgot about that but called!!
"Yes sir, just drop it off at the nearest repair center (not HD) and they will put in a replacement order. The new tool will then be shipped to you directly."
Re: Disinterred!!
>gotta like that!
Let us know if it actually happens :)
Rob
Re: Disinterred!!
JohnKJordan in East TN
>I'd like to hear how it works out as well. I have one of those bought about the same time. It's still spinning and nodding (knock on bubinga.)
