Dressing up plywood projects
Alan Tolchinsky
>Hi All, I'm going to make some bookcases which will be built in. Also I'll be making an entertainment unit, one of those low ones for an HDTV. I'm going to use hardwood plywood for this but I'm concerned the outcome will look too "plywoody" . Any ideas to dress up these plywood projects to make them look more interesting? Thanks.
Re: Dressing up plywood projects
Re: Use sliced veneered plywood
John Pappas
>Rotary cut plywood, where the veneer is cut from a log like a roll of paper is simply ugly.
>I think the main thing to do is use thicker edging. When I do plywood cabinets and such I try to never leave a 3/4" edge anywhere. Shelves are stronger with a thicker edge but mostly it just looks like a different wood.
As for the sides that's a tougher question. I'll be interested in the responses.
Patrick Schupbach
>You can "frame"the sides with thin stock to give a solid look.You could use contrasting woods as well.Good luck!
Alan Tolchinsky
>Thanks all for the ideas. I like the suggestions.
Joanne Adler in Pt. Pleasant, PA
>Alan,
I�ve made a few pieces with nice birch ply, edged in cherry. These pictures are terrible, sorry, but hopefully, you�ll get the idea. I�ve done edging, moldings, and base molding. I�ve strengthened shelves with strips thicker than the �� plywood.
The first shot is the side of a tv cart I built for my Dad. It�s a really bad photo, but the point is the edging, molding, and cherry drawerfront. The cherry ages beautifully and really makes a nice contrast with the birch ply.
For the bookcase I actually got to keep in my house, I used cherry to frame the top, thin �� strips down the upright pieces, thicker strips to reinforce the shelves, and to make a base molding.
And here is the bookcase (jam-packed, of course) with the cherry darkening with age.
