THE WOODRAT IS BACK!
Crosscut sled rail material?
Scott in Montana
>I'm pretty sure that this question has been addressed many times, but I came up with nothing when I did a site search.
What are your material preferences for the slot rails when building a crosscut sled? UHMW plastic, steel, aluminum, maple...? Any manufactured rails you like? I see a lot of variety on the market? I've used beech rails on previous sleds, but they eventually get sloppy.
Maybe I'm missing or overlooking an obvious choice?
Thanks in advance,
Scott
Re: Crosscut sled rail material?
Rod Peterson -- Ormond Beach
>I have a really nice salvage metal place near me. I picked up some ¾ x 3/8" brass bar for a very reasonable price which fit my slot perfectly. Notice that that is a nominal dimension, and the true dimension of your miter slot will be different from it by + a few thousandths to - a few thousandths. One may not matter and the other may not fit. I have a chart on my website which chronicles most of the major brands.
Rod
paul waddle
>I've had picture frame cutting slide for at least 20yrs,slides made from maple. I'm sure aluminum will work too,but may be over kill. You can however drill and tap metal,cutting an expansion slot to tighten,but I seriously doubt if its worth the effort. Are you using two slots and two strips? Seems that beach would last a long,long time. pw
Jim Dillon
>Scott,
I would use whatever nice hardwood you had on hand. In my case, I've used scraps of locust as well as oak. And I keep them well waxed. I have no experience with other types of wood or nonwood materials.
Jim
>I had a rather crude sled I made with a hardwood rail. Don't know what the wood was, just a scrap. Used it for years. It seemed a little sloppy but what I found was that by the time you had it in the slot and approaching the blade, it did not seem to matter. That is, with sis or eight inches of it in the slot a hundredth or two did not create enough of an angle to matter in woodworking.
OTOH, my son razed me about my crumby looking sled until I rebuilt it, using one of the after market slides from Woodcraft. It is aluminum with the internal adjusters that allow you to tighten the wedges in about three locations until the are "just right". So, now I have that. Its fine. Took a bit of fiddling to find the sweet spots. Too tight and it grabs in the slot. Had to clean the slot very carefully. Had to really wax both the track and the slot. Seems to be a little temperature sensitive where as the old wooden one was a little humidity sensitive. In the end it's fine, but I am not sure it is really any better than a stick of hardwood. And, I ahve not had it long enough to report on the wear factor, it may wear just as badly as the wood.
I'v e used 3/8 x 3/4 cold rolled steel keystock
Forrest Addy
>I've used 3/8" x 3/4" cold rolled steel keystock almost exclusively for all my slotted saw tooling. A 12 ft length is enough for severa; items, a sled, a penel cutter, a couple of dovetail jigs, a small slet etc. Brass is a good choice as is a stout hardwood. Aluminum although handy and easy to work wears the table slot a surprizing amount.
Some makers for their own ridiculous reasons have made their miter slots a trifle off from the nominal dimension. Older Craftsman saws come to mind. As Rod said, check your table saw's miter slot for size using a micrometer and an adjustable parallel bummed from a machinist friend. You never know when you might need a machinist type favor. If you know one checking your table slot might be a good reason to invite him over for a beer. He can help your with your metalwork; you can make him parts he can assemble into a wood tool chest.
Excessive clearance may develop in a sled key but a little muscle used to bias the sled to one side or the other will minimize angular error.
Plastic
>I use 3/4x3/8 UHMW stripping.
It's easy to set the strips in the slots and shim them (if needed) to be tight on the slots' inside walls. Then I place the sled over them with the centers marked, and drill & screw into the strips from above. This zeros out any slop in the slots because they're always indexed to the two inside slot walls. Same thing for my miter sled except I index between the outboard wall of the left slot and the left edge of the table.
mm
>I have some thick lexan that I rescued from a torn down sign. I use that. It never changes dimension and is tough enough to hole the screws.
One more thing...
Jim Dillon
>... if you decide to use wood, and don't have one already, treat yourself to a shoulder plane. It works great for fine-tuning the width of the wooden runner(s), and even for a hand tool klutz like me, it is really useful for other things. I have the Lee Valley medium shoulder plane and love it. Good luck with building your sled; it is the most useful TS fixture I have.
Jim
Johanna
>I have used hardwood and Incra Miter Sliders. My current sled has the Incra sliders. The nice thing about them is that they can be fine-tuned to exactly fit the slots in the saw. Here is one location for them: http://www.rockler.com/product.cfm?page=11337
Jay St. Peter - SoMD
>I've used UHMW on the last couple. I cut a slice off a piece of 3/4" UHMW I have. It fits my miter slot pretty tight. I can tighten the fit slightly by tightening the screws I use to attach it to the sled. It will slightly bulge the plastic and make a perfect fit.
Jay
Re: Crosscut sled rail material? *LINK*
John Ballance
>I've used hardwood, UHMW and the Incra miter bars, but the Rockler rail works the best, in my opinion. Self-contained spring loaded ball bearings keep the rail pressed firmly to one side of the slot, yet it slides easily. No affiliation, I just like that Rockler miter bar. I use the Rockler miter bar on my crosscut sled, which gets used all the time.
PS: They are on sale now - 2 for $12.98.
Good luck.
John
http://www.rockler.com/product.cfm?Offerings_ID=14
Thank you all for your valued input!
Scott in Montana
