Dust Collector follow up-- Powermatic 73?
mkula
>I wrote a couple of days ago looking for advice on DC purchase-- seemed to be most recommended that bigger was better, even if used.
Long story short, found a used Powermatic 73 (1 1/2 hp discontinued model) and I am sure someone out there has used/still uses one, and wondering what your thoughts are on it? Don't know about its exact age, but have a copy of the manual. One specific question is about its amp draw. The manual says it needs a dedicated 20amp circuit, but I don't have one for it. Just 115/15. I have read other posts/info about the actual draw on DC's being far less than specs say. Anyway--thanks to anyone who might have thoughts, advice, recommendation about going with this model versus a new 650cfm unit. thanks!
Re: Dust Collector follow up-- Powermatic 73?
>In my old shop I used a Shop Fox 1.5 hp unit on a 15 amp circuit. It worked - provided I didn't have anything else with a high amp draw on that circuit. You definitely can't have your table saw on the same circuit!
Ells
>Some 1.5 hp 110 motors can pull 16 to 17 amps on start-up so may depend on how fast the circuit protection is. I use a 1.5 HP DC (Delta) and works very well with 4"-port machines one at a time and keeping the hose run as short as possible, less than about 15 feet. I also run a room dust scrubber (3.5 amps peak) on the same 20-amp circuit and have not popped the circuit yet.
Jon Grider
>Hello,I saw your response and question about the PMTC 073 on the 'Looking For Something' board.My opinion of the 73? The scoop: It still works about as well as it did a decade ago.It adequately keeps up with my jointer,planer,and miter saw,but not so good on the tablesaw due to the difficulty in sealing all the open areas on my 66 TS.Of course I only use one intake at a time with a relatively short section of flex hose and wheel it around to each machine as needed.This can be bothersome at times and I have on my wish list a more powerful DC.As my other post indicates,finding the plastic bottom bags can be a challenge.I had resorted to layering 3[or4] 3 mil contractor trash bags which though serviceable does not give a great seal with the band strap.As an amusing anecdote,I first tried using only one 3 mil trash bag as a bottom bag.It took the 073 about 5 seconds to inflate the trash bag like an over filled balloon with the resulting 'pop' producing a pretty good sized dust cloud.So,if a small,a bit underpowered DC that is hard to find bags for but seems to be built well meets your needs,then go for it.
