>I need to make an 800 ft. run for cable TV and internet connection. My options appear to be cable vs. fiber optic, and, I am going to run it underground. Cable company wants $1450 to run it half way, hah, no way, this is DIY. Anyone with long range experience out there. DSL is not available and probably never will be, satellite does not have a clear signal and never will have. My DISH is out whenever it gets to cloudy and I'm not happy with it. Sooooo, long range cable is it.
>is about a 3db drop. Which means every 90' you will cut the power the cable company is sending you in half. Make sure you use the best cable around RG6 (I think it has been awhile). If fiber optic is an option that is the way I would go.
>Ray, any wireless broadband companies around there? I just moved and will be moving again shortly. Both my current house and my soon to be forever house are way outside the realm of cable. I ended up finding a wireless b-b company that services both areas. After a couple of days of dropped connections, I changed routers and the problems went away. I have not had a dropped connection for a month and the speed is at least as good as I had with cable. It costs a bit more per month, maybe $15 and there was a $500 installation fee, plus it will cost $100 when I move. I couldn't be happier.
>I've been a DishNetwork user for at least ten years. When I first installed it (when we were living in Illinois) I found it somewhat susceptible to the heaviest part of a thunderstorm—enough to be an annoyance when recording something, but in reality, it was way less than 1% of my viewing time. Although I went through a two or three year period without it in the condo in South Florida, I did eventually get it going there with probably similar results.
However, when I got everything set up here in OB, it came time to change receivers from the legacy 300 system to a 500 system with dual tuner DVR. The 500 system antenna is bigger and much better with signal acquisition (retention, actually). Outside of hurricanes when everything is lost, our lost signal episodes with thunderstorms can be measured in seconds (and infrequently at that) versus minutes with the 300 system.
I'd be surprised if you weren't a rock solid customer with the dish with a 500 system. Any of the places I've used a dish must be farther from the bird than you are. As I recall from visiting your place, you must have a wide open view of it. If you're not on a 500 system, take a look at it. I was amazed at how inexpensive upgrading was (although I am not happy paying a monthly lease on the receiver—in our original installation, we owned the receiver).
Yikes, unless there a mountain in the way or trees there must have been something wrong (alignment, dish, LNR, connection, cable).
I had a Dish TV and a Direcway satellite for several years before I could get cable to the farm. Neither went out except for a few minutes in a severe thunderstorm. Once I had to sweep 2" of snow from the antenna.
I don't know about your transmission question. When I finally got cable installed for TV/internet they ran 600' underground they installed a flexible conduit (about 1.5" dia) and ran a special cable inside. This went to a box where a connection to an additional and smaller 100' underground cable to the house. There a connection with at least 75' off regular cable stretched around and through the house. (are we close to 800' yet?) The signals for both TV and internet are strong and clean.
BTW, Comcast will install up to 600' underground at no cost. (at least they did for me a couple of years ago)
>I suspect that your Dish equipment must be either mis-aimed, defective, or merely a lemon. The microwave frequency used for satellite-to-earth are susceptible to absorption by water droplets of a given size but mere clouds should have no appreciable affect on them.
As for running 800' of 75-ohm coax, presumably buried, I'm at a loss (as is the cable). The losses of even the best coax is going to pretty much murder the signal and is going to be very expensive to experiment with. Even a relatively low-loss cable like RG-164 is going to be problematic and is not fun to work with. Perhaps some sort of heliax might work but the price is many times higher than even the best standard coax and I suspect that connectors/adapters will be a problem for this application.
>The dish is mounted to the house on the south side and I think it clips the tops of the trees. Any time there is rain between me and the satellite I lose the signal, up to 4-5 hours at a time(worst case). Of course the installer went out of business right after I put in the system which left no one to complain to. I put in the system when I built the house 'bout 5 years ago, at that time the cable company wanted $1200 for installation and two years ago they wanted $1450 just to run it to the barn (halfway to the house).
>As we speak the sky is clear as a bell and the thing is switching between a signal and aquiring a signal. When I go to the diagnostics the system says it has a good signal. I'm getting really fed up with it, heck at this rate a tower, rotor and antenna is not out of the question. If I could get an old movie channel on an antenna I would change in a heartbeat, its just background noise anyway.
>It is supposed to be good for up to 1000' and you can get it in an underground version. I am thinking fiber would be better but I don't have any experience with it, and it comes in an underground version also.
>When I was set up in the condo, my antenna was indoors! No, not seeing through walls, but aimed out of a window. Now, to be fair, I had to have the window open some, as the tinting film which had been applied by the previous owner apparently had some metallic component—it was like throwing a switch when I lowered the window. Anyway, I had nowhere near a full aperture to that antenna, and I still got serviceable signal.
Granted, if you're on the south side of the house, you may be in marginal territory, but I don't remember the trees being that tall. The bird sits a lot higher off the horizon than the angle of the dish suggests. It has a parabolic shape and the LNA/LNB sits off axis a bit, accepting the satellite signal off axis as well. In any event, just moving it to the west facade somewhere should solve that problem.
“up to 4-5 hours at a time(worst case)…” There's something wrong. In all the years I've been on the dish, I don't think I could even total four hours. Talk to DishNetwork. They'll put you in touch with a relatively local installer who can set you up (get you back in shape) for pennies compared to the potential $$$ you're talking about for laying cable. I would imagine Direct would do the same, although I have no experience with them. Dish is very competitive, though, and work very hard to get customers online.
>We had a 450ft run for the house and we could not get clear pictures on high stations like 78 and up. That was RG-11 that the cable company put in. 2 cuts and splices from the neighbor hitting it was all it took to drop the signal enough to ruin most everything. The guys who finally came and put in a new pedestal said that Comcast has a 300ft policy due to signal loss. You might have to have them put in an amplifier and a new pedestal. If they say that 900ft is too long, listen to them. We now have a new pedesal and the builders run of about 75 feet long and 5ft underground and the signal is great. They might work with you on the amplifier and then give you the cable and you can bury it at your cost. In our Denver area they put the cable down 6 inches, so it's pretty worthless.
>Ouch! We live in the mountains of New Mexico -- no view at all of the southern horizon (there's 4000 more feet of mountain in that direction), so cable was our only option. The fee to install was minimal. They had to go from a neighbor's pole to ours, then from our pole to the house underground. Since they had to go around the barn, it's at least 200 feet. The cable is only about 6" underground.
We did have a problem that they finally resolved, but it was on the neighbor's utility pole and occurred when we had bad weather. Works just fine now.
>Take a TV and the receiver out side and place it on the tail gate of your truck. Now climb the ladder and lossen the veritcal adjustment (should be 7/16") switch the set on and the receiver on and go to setups aim dish. Watch the screen and listen to the tone the higher the better. Next do the horizontal. It only takes a 32nd" to make a big difference. I used to install these things and this is how I did it. Switch back and forth betwen vertical and horizontal until you get the best signal. Then tighten the bolts. I used to use red lock tight to hold them. It can't get worse(-;
Never try this with the LOYL inside yelling out to you it never works out that you are in sink, and causes undo stress.
>hook the Dish LNB to the receiver outside you will need to remove the thing (LNB/LNA) on the post in the middle of the dish. Should be a phillips screw on top. replace one cable down the feedhorn to thhe receiver. Then go to the above post.
>if not then the Receiver may need replacing and it may be time to work out a free upgrade cause you are going to switch to Direct TV and they are offering XYZ. In other words play the two against each other and get the best package you can.
>I agree with Rod 100%. You have either an antenna aiming problem or a loose connection between the antenna and your receiver.
First off, the main dish satellites are roughly positioned over Los Angles. For the 47160 zip code area, you antenna should use the coordinates of 223 azimuth, 36 elevation, and 121 skew.
Look in your yellow pages and call a Dish network installer. When we moved into our home in 2002, I mounted the antenna and hooked up the cables. Then I called a local dish installer to come aim the antenna. It cost me $65 for his work, but he had the instruments to do it correctly where I might of spent several days getting it right. It took him about 10 minutes.
So before you go off the deep end, skin the first bear; get you existing system working up to spec. Then if it is still a pile of brown stuff, you have good reason to spend your money on another alternative.
Lastly, if you have some big tree branches in the way of the antenna, they could impact your antenna performance. Perhaps some pruning is in order? Also, may be the original installer didn't get the mounting clamps tight and the dish has windmilled slightly off target.
