Flex-Lock vacuum hose
Jerry Klug
>I am trying to locate a supplier for Rigid Flex-Lock hose. It looks like snap beads with a hole through it big enough to work at the end of a shop vac hose. Peachtree had them at a past Woodworking Show for drill presses but I dont need the $40 kit, only some hose.
Re: Flex-Lock vacuum hose
Stuart Johnson
>I think I saw some advertised by Lee Valley.
Re: Flex-Lock vacuum hose *LINK*
>McMaster-Car 6503-T21
McMaster
Bob Entwisle in NJ
>Try this link
http://www.modularhose.com/
Saw that ! . . .
steve mackay
>Mr. Lee has the flex-hose and that cool magnetic chute. Was just made for my drill press ! Luxury so I'll have to save up my pennies.
Re: Flex-Lock Strengh
Stuart Johnson
>How strong is Flex-lock? It looks like it might work for an adjustable task light if it is strong enough. The OD of the 1/4" is .64 so it would probably fit inside the 3/4 ID. It would be fairly easy to make a base, feed a cord through and attach a lamp head if it is strong enough to support the head it could be mounted on the lathe and be moved where it is needed.
Jerry Klug
>Thanks for the great contact information. I couldn't locate a site on the web as I was calling it "Flex-Lock" instead of Lock-Line". Now I can finish the vacuum pick up for the LOML's scroll saw.
