Not uncommon in a dado set.
Forrest Addy
>Ths problem you describe is not uncommon in a dado set. Fortunately, a good finish on dados and grooves is not a real necessity. In most woodworking, a shelf or something is glued in it concealing the irregularity forever. However knowledge of a less than perfect finishes and joint geometry anywhere detracts from the pleasures of fine woodwoking. The problem derives from the relieved diameter of the threaded arbor and the tendancy of the thinner chippers to drop slightly between thread crests if there is room for them. A saw arbor is a weak design; there are many disadvantages and few benefits to an Acme or square threaded arbor.
I always thought woodworking machinery should borrow from metalworking and use a self-releasing taper to locate spindle tooling and adaptors to interface betweeen cutting tools and the spindle (arbor). The adaptor would fit a keyed 3 1/2" per ft taper on the arbor and be retained with an allen screw. Thus all woodworking saws and dado heads, molding heads etc would have a precise 1 1/4" bor that fits a unuversal hub on the adaptor.
This is not only more precise and rigid but tooling changes are quicker. A half dozen hubs and you could have the all-purpose combo saw, a thin kerf, the junk nail cutter blade, the dado head, a molder head, etc all set up for quick and ready swap. And you can assemble the dado head out where you can get at it instead of in the bowels of the saw table.
I've sketched it out a time or two ahd the whole system would impose no bulk that would inhibit the range of motion or adjustment of the presently used table saw design. In fact the hubs would be almost identical to those used on tool and cutter grinders.
But it's expensive and saw arbor tooling to be used with it would have to be bored to suit the hubs. Don't look for it in the near future.
