Question for Dan Mitchell (OT)
>Dan, you trashed a hot tub/spa. by any chance did you save the controls? My friend is trying to fix hers and I thought if you had the controls, they might work and I could buy them from you.
Re: Question for Dan Mitchell (OT)
Dan Mitchell
>Barry - If you mean the box with the main circuit board that sits beneath the tub, yes I do have it. It's a "Discovery Spas Control System model ZX1000". Looks fine except one of the terminals to the heater is a bit corroded, and the insulation to that particular wire is slightly melted (no doubt as a result of heat from the added resistance of the corrosion). I think the terminal would likely clean up fine.
If you mean the small panel with a couple dials that was on the edge of the tub itself, I think it may have been sawzall'd in 2 when I ripped the bloody thing apart.
If you or your friend can use the panel, I'd be glad to send it to you for shipping costs.
Dan
Dan Mitchell
>I should add the date on the control panel is 1993.
>Thanks Dan. She is checking. We are also looking into a complete rebuild of the controls. I will let you know. Thanks again.
Also have this
Dan Mitchell
Re: Also have this
>Thanks Dan. She is checking to see what a complete rebuild will cost. I will let you know soon.
Sent you an E-mail.
