How do I do I make these?
Lee Schierer - McKean, PA
>I have been asked to make a replacement piece for an antique cabinet. Most of the part is pretty simple, but one detail has me stumped. How do I make the grooves shown in the attached photo? They need to run the length of a 24" board on two sides of the board. The boards are 2-3/8 wide and the grooves are more or less centered on that width. I have two pieces to make so I need to make the grooves a total of four times, all the same.
Thanks,
Lee
Re: How do I do I make these?
steve mackay
>I would run 'em on the table saw then sand with shaped sanding blocks. But thats probably the cheap way out. Then theres molding planes and beading planes ( slip-slidding-awaaaaaaaaay ! ).
Dale Lenz
Dale Lenz
>There used to be molding blades for table saw, have one, but could not find it if my life depended on it. Molding blades were once thought to be finger eaters, scared me. Have you looked at router bits?
Good luck
Should have called attention
>Note the total size of these grooves and bumps. Molding head cutters and router bits that I've found cut 1/4" wide humps and usually cut three of them. The total width of these cuts is less than 1/2"
Lee
Jim Toews - Walla Walla, WA
>Lee,
You could make a scratch stock any size you want. Run it against a fence and you could put the beads anywhere you want. Just a thought.
Cheers!
Jim
Sean Troy
>You could use a Dremel with the Multi Purpose Cutting attachment. Verticle kind of like an edge trimmer. they have the small bits that should work just fine with a little sanding afterword.
Robert R Clough - Thorncraft
>This may be a somewhat strange answer, but if I had to do this, I'd look at using my Stanley 45. I have th proper beading irons and could, I am sure, set the plane up to do it. The only other way I can think of is a beading bit in a router table.
Dave Arbuckle, Plano, TX
>I was thinking the same thing. Although there's eight feet of it, the profile is so small that making it with a scratch stock would probably be easy.
I love the look of hand-scratched beading, it somehow has more life to it than machine-made does.
Magic molder.... *LINK*
JT in Michigan
>probably a little pricey for a few feet. Use a P-71, P-72, or P-75 cutter depending on the exact size of the beads.
Magic Molder
Warren in Lancaster, PA
>I think this would be less than an hours work with a scratch stock. Perhaps 15 minutes making the cutter and 30 minutes scratching, less if you made one long board. It is helpful to leave extra wood on the ends of the stock because the scratch stock doesn't do so well at the beginning or end of the cut. A molder would make quick work of this, but it is not economical for such a tiny amount.
suggestion
Bill Tindall, E.TN
>Scraping these short runs is surprisingly efficient, or at least I was surprised how easy it was when I was finally forced into trying it. You can file a scraper from metal banding stock or a card scraper, or a wide band saw blade. File the scraper and leave the filing burr.
Scraping goes even quicker if you use some sort of power tool (router or saw) to remove as much wood as possible before scraping to the final profile.
Of course walnut is going to scrape easier than red oak. The picture looked like the piece might be oak and I'll bet oak with its hard and soft spots it doesn't scrape easily.
Gary Karner
>Hey Lee, been a long time since we "talked".
I'd make a scratch stock, you'll use it the rest of your life.
Here's some great help by Bugbear.
http://www.geocities.com/plybench/scratch.html
Re: How do I do I make these? *LINK*
albertabob
>Your fastest bet and probably least expensive is to try to find a table saw molding head with the right profile.
They were very popular when furniture featured more decoration.
Regards
Bob
Tom in Tipp
>If there's room I may run a shallow groove with the tablesaw to remove excess material and give the scratch stock some direction. Not really necessary but it may help some.
Tom
Tried it!
>I tried making a scratcher. It took about 30 minutes to make one once I figured out what steel I had that would work. I used an old hacksaw blade. I filed the profile I needed in and made a U shaped slide to hold it aligned with the board. I tired it on a piece of scrap first to get the scraper cut just right and mounted so it would work efficiently. I did both sides of my 6 foot board in about half an hour.
I'll have to make a second one for the edge beading once I get the board cut to final width.
Thanks for the idea.
Lee
Re: Tried it!
>Lee, I was afraid you might not try this, so I'm glad to hear that it worked out. We use it quite a bit in the restoration trade for delicate moldings. I does not work very well in softwoods.
