Can I get some input on selecting a quality marking gauage - type with single cutter knife. I'm attending Mark Adams jointers class in IN. A friend offered not to bring a Crown. Other possibilities? Thanks
>Google- Tite-Mark. The Glen-Drake Tite-Mark (tm) is a great "system" - a single bevel wheel marking gauge that's been refined to the Nth degree, with very fine adjustment for bevel edge to "fence". With accessories it makes pretty precise layout a lot easier than the traditional "board, stick and nail, or knife" marking gauge. And, you can use an existing
scribed layout to set it to, and do that easily and precisely.
The link below has a photo of this tool and its accessories. The next page has examples of how it's used.
Note that by loosening both thumb knobs (?), the fence moves on the shaft freely for getting close quickly. Tighten the rear knob and then turn the gnurled internally threaded "sleave" to move the fence foreward or back pretty precisely. When you've got the setting you want, tighten the fence side knob to fix that setting. No "loosen the thumb screw - get close, tighten the thumb screw and things move a little, loosen the thumb screw again and nudge in an adjustment . . .".
And when it comes to laying out the sides of a mortise use the "mortising wheels". Mount them on the shaft, tighten one, move the other to the width you want, tighten it and THEN set the distance to the fence. With a two stick wooden marking gauge, every time you move either stick you loose the spacing between them. Not a big deal if the fence to mortise distance from the mortise reference face AND the tenon reference face. But if you're doing a Leg To Apron M&T joint and want the apron set back - things get a little trickier when setting up a two stick marking gauge.
If you look at the second page reference earlier, not that the mortising wheels are single bevel and can be mounted on the shaft flat face facing each other or away from each other - the first orientation for marking the mortise and the second for marking the tenon. Subtle thing but a nice refinement.
Lee Valley has a similar, less expensive, version of this wheel marking gauge - BUT - it doesn't have the accessories and the capabilities the Tite-Mark has. Glen-Drake even machines a recess in the face of the "fence" into which the cutter wheel can be
withdrawn - and PROTECTED.
Oh - and if you've ever had a wheeled marking gauge roll off the bench onto a concrete floor - you'll appreciate that the thrumb nobs/screws are long enough to allow only one rotation before they stop the rolling.
BWT - it also makes a nice depth/height measuring device - nice when checking mortise depth, setting saw blade height, router bit depth of cut . . .
If you're a real traditionalist, go with a stick, board and nail. If you want an easy to use, precise to set, versatile marking system - seriously consider the Glen-Drake Tite-Mark (tm).
Now if you're thinking "This guy must be a Glen-Drake shill" - I have NO association with Glen-Drake other than having bought one at list price with my money - and used it a LOT when building my "real" woodworking bench.
I've bought and tried the others. This one works best - for me.
charlie b
ps - nice drive by gloat - the Mark Adams school thing ; ). He has a passion for woodworking, the skills and abilities - AND is a great, enthusiastic teacher.
>Why not make your own? I made a few of them, and try-squares and gave them to my sons for Christmas gifts. They are easy to make, and just as accurate as any store bought gauges.
Wood Magazine has an article with drawings and specs on thier website at: http://www.woodmagazine.com/wood/story.jsp?catref=wd47&storyid=/templatedata/wood/story/data/1139514747046.xml
What better way to "show off" your skills at the school?!
