Looking for a printed Article FWW?
Alan Young
>A few years back (3-5?) Chris Gochnour wrote an article that I thought appeared in Fine WoodWorking on building a French Provincial Case Piece. I am working on a design that has that general flavor. Part of the design is a swooping cove molding that runs around the top.
I think he did this by making strait sections in the table saw -angling the piece across the saw and making several cuts raising the blade each time.
I think he made the corner pieces on the lathe matching the profile than cutting them on the table saw at 90 degrees...
Thing is it seems you can only get 1 corner piece out of the turned sections as the kurf of the saw blade will reduce the radius by 1/8" of an inch on the cuttoff....I want to figure out if I have to make two of the round pieces to yield the two corner sections. I'd like to re-read the article. I am sure I have the article somewhere in my stash- thing is the stash is spread out over a couple of stacks and locations and if I at least knew what issue to look for that would be helpful....
BTW A serch of the FWW site produced 69 articles but I couldn't find the one on this topic. I can see the pictures in my mind....It was really a great article. Details on running bead lines around cabriolet legs, raised panel doors with that jogged curve...I though for sure it was FWW.So if anyone recalls this sort of article in a PRINTED publication and can track it down I'd really appreciate it.
Thanks folks
Alan
